Need Help
Old Jul 6, 2004 | 10:39 AM
4th Gear
Need Help
How do you remove the Distributor cap. It seems to be wedged between the engine & firewall. any info will help...
Old Jul 7, 2004 | 09:47 AM
982.5TL's Avatar
All about JDM
I have the helms manual to the 2.5. Ill look it up later today and get back to you. Unless u have a 3.2.
Old Jul 7, 2004 | 09:48 AM
4th Gear
Please do I reaaly appreciate that Thank
Old Jul 7, 2004 | 12:09 PM
TLBaller's Avatar
off the subject here but wow, our age is posted up now. i thought 982.5TL had only 20 posts lol
Old Jul 8, 2004 | 08:25 AM
982.5TL's Avatar
All about JDM
Ok, I looked in the manual. All it says is remove the spark plug wires, and remove the distributer cap. lol. It doesnt have any specifics on how to get it out easily.
Old Nov 1, 2004 | 11:33 AM
Quatro40's Avatar
Hi, first you need to remove the spark plug wires, then your battery, detach the aluminum plates that protect the battery, then finally, you need a socket wrench think 12mm to remove the two screws, there is one on the lower left corner and another in the upper right corner.
