Loose Steering Wheel FIX
Hello I was thinkering with the car today and found out how to fix the loose steering wheel problem
First take of the two steering wheel covers, then with a 14 mm socket wrench tighten the lug not with the white ring around it *directly opposite the axle of the lever* and thats it.
Rectification
follow the above steps to take off the cover, but you have to loosen a bit the smaller nut and align the metal plate then you can tighten the big nut. if you don't loosen the smaller nut first (you can see that is making the metal plate lift out of place) the wheel won't be able to support its weight when you tighten the big nut.
