Intake on the 3.2
Old Oct 4, 2002 | 05:57 PM
shaolin1's Avatar
Intake on the 3.2
for those of you all with intakes on your 3.2's, when you put it on, do you get a higher-pitched whirring sound @ idle? I dont think it's supposed to do that. Also, re: the 3 hoses coming off, does anyone know specifically what each one is for? Thanks!!!
Old Oct 4, 2002 | 05:59 PM
shaolin1's Avatar
I kinda remember this discussion re: intakes on the 3.2 in a thread probably over a year ago.... and someone was talking about taking out the white thing behind the bumper that goes into the filter area. Someone help.
Old Oct 6, 2002 | 05:12 PM
intake
did you find one to buy? i have been looking all over and i cant find one made for our cars.
-will
Old Oct 6, 2002 | 08:39 PM
shaolin1's Avatar
well, i bought one used with tubing that fits, but with only 1 nipple. So now I dont know which one to connect. Anyone with experience with other cars? Is there supposed to be a constant high-pitch at idle.... it sounds like just air rushing in... but didnt think it would do that at stand-still....
Old Oct 6, 2002 | 10:55 PM
KaMLuNg's Avatar
yeah u will hear a small hiss... that is normal for intakes... however there should be two nipples... what car did this intake come off of???
Old Oct 7, 2002 | 07:40 AM
shaolin1's Avatar
who knows, it worked on a 3.2 before apparently. Anyway, do you know what each of the hoses are for? i would assume one is for the O2 sensor....
Old Oct 9, 2002 | 02:27 AM
YNOTxTONY's Avatar
None of those are for the O2 sensor. The O2 is electrical/electronic and is part of the emissions, not the intake/fuel system.
Old Oct 9, 2002 | 10:32 AM
KaMLuNg's Avatar
well what u can do it connect the one nipple u have to the front of the engine.. i can't go out and take a pic righ tnow cause i am on my laptop and my desktop is dead.,.. but what u can do for the engine valve cover is leave that box that connect to it and just put a bloww off value on the end.. that way it can suck air in manually... dunno if that would work to well just giving idas... someone plz check this over... or u can just make another nipplke of ur own....
Old Oct 9, 2002 | 06:06 PM
shaolin1's Avatar
blow off valve or breather filter?
Old Oct 11, 2002 | 12:50 PM
shaolin1's Avatar
how do you make a new nipple on your own? anyone ever done it?
Old Oct 17, 2002 | 07:32 PM
YNOTxTONY's Avatar
It's not worth it to try to make a new nipple, unless you know how to work with aluminum. Even then it might not be worth it.
You should start out by getting the correct one for the G1 TL.
Check this out http://procarparts.com/store/display...AC-CL-9798-AIS
Old Oct 17, 2002 | 10:16 PM
shaolin1's Avatar
is this confirmed to fit?
Old Oct 18, 2002 | 07:26 PM
shaolin...
the intake is supposed to fit our first gens... it is the same one from procarparts from what i understand....
from what i know, the guy i got it from, he had one breather filter coming out from the side of his engine.. hence he did not need the second nipple
hope that helps
Old Oct 18, 2002 | 08:09 PM
shaolin1's Avatar
yeah it does, thanks...haven't seen you on here in awhile. There is one last thing tube that comes from the base of the throttle body. anyone have any clues?
Old Oct 19, 2002 | 02:04 AM
i'm glad it fits...
haven't been here cuz i've been really busy with work and stuff.. been trying to work on my 240sx...
base of the throttle body? from what i know the hose goes into a hole towards the bottom of the engine and the breather filter goes somewhere near the top of the engine, (on the left hand side)
hope that helps...
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
Pham Alvan
Mar 16, 2016 09:17 AM
