Intake for 2.5TL
What size of cone K&N filter did you put and did you take out the stock air filter box? If you did, what happened to the air flow sensor.Please if you have any pictures post it so I can see exactly what you did.Thanks
simply remove the air filter box. you keep the o2 sensor where it is, don't mess with that. just unbolt the box. the box and the rubber tubing can be easily taken apart. i forgot what the diameter of the filter is, do a search on this site and i'm sure someone post it up before. and simply just clamp the new filter onto the hose.
there is something attached to the top of the box,it is shaped like a rectangle and it has (HONDA 3798-PIR-A01 and at the bottom "Made in Japan") written on it,it is also attached to the car with some kind of wire. Do you take this off with the box b/c it will not detach from the box.Please let me know.Thanks.
hehe if i turn off my radio and just listen to the car, i can hear a high pitched hissing sound right when the car hits 3500 rpm. it's such a beautiful sound. but usually my exhaust drowns the sound out. hehe.
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
