Inspire Help
'13 Hyundai Sonata
Inspire Help
I would of tried a search but I have no idea where to start. I'm in the process of installing my Inspire tails and I tried to take the nuts off that hold the tails in, but there was no way that I was doing it by hand. I was wondering for those of you that have done this how did you get them out. If anyone used a driver to take it out can someone please tell me the size because doing it with a drill and a driver would be so much better then doing it by hand.
'13 Hyundai Sonata
Originally Posted by lg562
another thing about installing inspire tails, its easier to swap the usdm wire harness onto the jdm tails so you wont run into any brake light problems
Take it easy haha. Take a look at the back of both taillights and you should see a little box on one of the two harness. Try putting that harness with the box on the other side (on the other taillight) and it should work fine. If not, bulb maybe? Good luck and make sure to post pics in the gallery!
i tried to use the JDM harness first, and it messed up one of my brake light bulbs. i switched to the USDM harness, bought new bulbs and my Brake Lamp light went away. everything has been working correctly
InFaMouSLink
10-27-2015 06:51 PM
