Help, stock alarm goes of randomly all the time
Hello, everyone, I just got a 96 3.2 TL and after two days the stock alarm started to go off at any time for no reason. I read the TSB in this forum but how do I get that lock, and is it possible that there is other reason? Can someone help me with a wiring diagram or instructions how to turn the alarm off myself?
Thanks in advance, I appreciate your help!
What do you mean?
On the battery side or the chassis? I havent but I will.
I was also wondering if I could follow the TSB posted earlier that says the trunk latch is the probable cause. But instead of replacing will it work if I pull it out, clean it real good and put it back in. Anyone with similar problems?
I once had a problem w/ a 94 Accord factory alarm w/ similar random alarms. The battery voltage was declining, althought the car started fine. When I finally noticed some hard starts and replaced the battery, the problem disappeared and did not return. If your battery is old, you might check the voltage. Not sure what the critical voltage is, but probably something less than 12V will set the alarm off.
good luck
good luck
Well, I just got back from Autozone - they have free battery check, it's not the battery, although it looks old it had 12.9 V and under load went 11.27 V the lowest so it is good. Now it probably is the freakin trunk latch... any ideas?
Battery is probably eliminated as a problem. They did a load check to verify the voltage doesn't decay rapidly? Just measuring the voltage on a car that was just shut down is not an adequate battery check. You should start the engine a couple of times at least and then check voltage.
I have a 99 Subaru that occasionally alarms, primarily in parking garages. I've traced the problem to the "breaking glass" sensor. A loud exhaust such as a motorcycle is particularly good at setting off the alarm. In a car garage, the noise is amplified and I have to disable the alarm before I leave the car.
good luck
good luck
handsom-hustla
11-13-2015 05:04 PM
