Help, my check engine comes on
I already did take off both the battery terminal and touch it together for 1 min, restart the car and the light still on.
I heard that if you switch gasoline brand, the lights will comes on, I was using Tesoro 92 gas for the last 6 yrs, and on the last 2 fill up, I use Chevron 92 oct, will that be the cause??
Is there a terminal below the glove box that I can connect to see the problem code?
I have a 96 2.5 TL
I have a 96 2.5 TL
You probably have emission problems. Take it to the dealer and have the car checked for the recall. Otherwise, the terminal should be under (behind) the ash/coin tray. Just grab the lib and pull up and out.
anyone with a manual that wants to help???? have u been blowing any visible smoke outta ur exhaust??? gotten a tune up lately??? the gas could have something to do with it especially where u get the gas... happened to my old car where i later found out that the guy was watering down his super unleaded gasoline....
Billu99tl
09-13-2015 11:30 AM
HeloDown
09-08-2015 06:51 PM
