Help finding power steering hose replacement
I need to replace #12 in the pic, part # 53731-SW5-000, which is the suction hose going from the reservoir to the pump.
I found "return hoses" on the discount auto store websites for $12 to $16, and the description tells me that those would be #14 or 16 in the diagram.
http://shop.advanceautoparts.com/web...raft_3867404-p
Can I use one of these in place of #12?
I can get the exact part for around $30 from Acura but it's just a regular rubber hose, not high pressure, and I want to know if I really need to get the Acura part.
Thanks fellas.
Ok I examined the hoses on the car and the suction hose that I need is definitely larger than the other two hoses going into the reservoir.
That being so, does anyone know the specs on the suction hose and if I can get it on the cheap? Thanks.
I haven't look in my engine bay yet, but you might be able to get by with a universal hose of the same inner diameter if you can route it to the pump safely. Otherwise, the dealer would be the only place to get a hose with those specific bends.
Yes the bends near the lower end are what could prevent me using a regular hose, but I think I can tie it to something to keep it away from the engine block. Plus that hose has 2 or 3 clamps along the route.
Any idea what the inside diameter is?
I guess I can just pull off the reservoir end when fluid is low and measure it.
Thanks.
Thanks.
cycdaniel
12-17-2019 10:58 AM
mike from annapolis
05-07-2017 08:21 PM
asahrts
09-04-2015 05:55 PM
