headlights messed up
Old Dec 23, 2008 | 02:12 PM
matthowe71's Avatar
my daytime driving lights work, when I turn the headlights on left one goes out...in high beam position left light comes back on and right light goes out???? .....any suggestions guys?
Old Dec 23, 2008 | 03:01 PM
TexasHonda's Avatar
New bulbs. There are two filaments in each bulb. Left hi beam filament is out, and right lo beam filament is out.
good luck
Old Dec 23, 2008 | 04:04 PM
matthowe71's Avatar
Thanks Texas but I forgot to mention that I have replaced both bulbs......
Old Dec 23, 2008 | 07:11 PM
TexasHonda's Avatar
Make sure you have the correct bulbs for your car. Check bulb filaments for continuity w/ VOM. Next check contacts in bulb connector for 12V when lights are switched on. It's possible you have a burnt damaged connector or lot's of dirt in connector.
Wiring fault is possible, but less likely.
good luck
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
thegipper
Sep 28, 2015 01:01 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
