Ground Control coilovers or Sprint springs???
alrite guys...i'm looking for good suspension performance for my 2.5 . So which would u prefer...the GC or Sprint springs? BTW...are springs less bouncier than coilovers?
From what I think, coilovers are way more expensive, but are adjustable and perform quite a bit better...but if your car is just a daily driver, I would think springs would be good enough, as long as you have some nice tires/rims. But I dont know a lot about suspension, I'd like to see someone clear this up for me too
for how bouncy a ride is thats based upon spring rates. i dont know much on the sprint springs but i know ground control coilovers you can order a custom spring rate and choose how you like it. ground control coilovers also use eibach springs so thats an added bonus
Reppin' the T-Dot!!
1 Post
There are two kinds of coil-overs....TRUE coil-overs are a spring/shock replacement with the coil around the shock. There are also the type of coilovers that just replace the spring and have a collar to allow for adjustments. (ie Ground Control). These work well, but if you go too low, you'll blow out your original shocks wuite quickly and have to replace them anyways. You can always get the G.C. coil-overs then add a regular performance aftermarket shock after the other ones blow.
Received 2,329 Likes
I highly recommend Ground Control for our cars
For that setup, you need to make a decent investment though dont you? If I remember correctly, upwards of 1,000 bucks...where just a set of nice springs will cost about 300 shipped...and with tires and rims should do the trick...or am I way off (which I fully admit, could be the case).
well true coilovers will cost upwards of 1000...this isnt a true coilover setup but it's as close as you can get to it. you can get ground controls made to fit certain shocks like koni yellow's so that it's setup just like a true coilover but for less...the only downside is these can only be used with koni's so when it's time to get shock replacements you gotta shell out for koni's
joflewbyu2
10-08-2015 11:16 AM
