Gasoline- what kind and its worth.
I've always known that our cars require premium gas... But I've been putting regular in it since I've had it (a bit over a year now). I've never had any problems with power or performance so I never saw a reason to use premium.
Is it worth putting in premium and if so, why? (ie, do I get better gas mileage, more power, etc.)
Received 2,329 Likes
Why? Higher compression engines require higher octane gas. If you put in regular, the engine changes the spark timing a bit so that you have reduced power. This is done to prevent the gas from exploding prematurely. Higher octane gas has a higher resistance to detonation.
http://www.acura-tl.com/forums/showthread.php?t=95158
Oh yeah, our cars have knock sensors. But they can only stop it once knock has already happened.
Premium grade gasoline typically has more detergents because its a company's flagship product.
Swift 3 B-A-N-G-E-R
I fill my tank with the 89, then when it's time to fill it again I go with the 91. The thing is that when I fill it with the 89 it seems to get better gas mileage compare to the 91 which gets slightly less, but its preformance improves. So either way, it's a win win situation!
Eggs999bacon
09-24-2015 10:08 AM
