Engine Mounts
Old Jan 19, 2009 | 02:10 PM
Mr_Outside's Avatar
Engine Mounts
What are the symptoms of worn engine mounts? Both Honda and my local shop have told me that mine are worn and need to be replaced. I was wondering if there is anything you can feel or tell that your mounts are worn out.
Old Jan 19, 2009 | 02:54 PM
main70072's Avatar
There might be some jerking when putting the car in gear. Also, abnormal vibration at idle and maybe at a certain speed of driving may be present.
Old Jan 20, 2009 | 06:11 PM
Majofo's Avatar
Originally Posted by main70072
there might be some jerking when putting the car in gear. Also, abnormal vibration at idle and maybe at a certain speed of driving may be present.
+1
Old Jan 20, 2009 | 10:20 PM
Ken1997TL's Avatar
+ 2
Put your car into neutral, then drive, then neutral. If you feel a noticeable jerk in the driver's seat you have a bad mount. It is usually the rear mount where the transmission is.
Old Jan 21, 2009 | 10:25 PM
Mr_Outside's Avatar
+ 2
There is a jerk when I do this. From what I understand I have 2 worn mounts.
Old Jan 21, 2009 | 10:29 PM
TLin401's Avatar
'13 Hyundai Sonata
Here is a thread that I thought might help you. https://acurazine.com/forums/showthr...=mounts+engine
Old Jan 26, 2009 | 06:05 AM
Luke7's Avatar
WNC Real Estate Sales99TL
The front mount right behind the radiator and the side mount beside the engine that's mounted on the fender well area are the mounts that went bad on my 99.
You can have someone sit in the car/apply the brake/and while you"re looking under the hood/preferable from the side of the car so you don't take the chance of getting run over!/apply a little gas to the enging while it's in drive/you will see the engine raise on the front mount. If it raises up like mine did an inch or more you'll know the mounts are bad. I replace them myself. Quite easy if you have the right tools. The front and side mounts were about $140 for both ordered from Acura online. There are after market mounts that are also recommended. Do a search/there are lots of posts here.
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
Mr.Tea
Sep 14, 2015 09:58 PM
