Embarking on a 1200 mile journey
1998 2.5TL
Folks, I'm relocating from Birmingham, AL to Boston, MA in September for a new job. I've decided to drive my car to Boston, which is a 1,191 mile journey from where I live.
Some details on my car:
1998 2.5TL
Current miles: 154,9xx
Maintenance performed in the recent past:
1. I had to change the Cam sensor, so changed the timing belt, water pump, tensioner and thermostat as well - 700 miles back (Drive belts were replaced at 105K and they look solid).
2. Replaced fuel filter - 700 miles back.
3. Changed battery - 2K miles back.
4. Replaced brake fluid - 7k miles back.
4. Changed transmission filter screen and replaced differential oil - 2K miles back.
5. Replaced spark plugs, wires, distributor rotor cap, enginer seals and valve cover gasket - 16K miles back.
6. Replaced air filter 27K miles back.
Everything except the battery was replaced with parts from Honda/Acura.
Do you think I've missed anything? Or should I be good for the drive with all the stuff I've had done. I'm planning to split the journey evenly across 2 days - 600 miles on day one and 590 on day two.
I intend to keep the car well beyond 200K miles, hence all the maintenance. I hope I should be good for the next 60K miles... barring the usual ATF and filters replacements.
I'd love to have your insight into this.
Thanks!
1998 2.5TL
Thanks!
u should be good... i drove my 98 TL 1600+ miles from Dallas to NJ last year without any major maintenance beforehand... u should be good as long as the car is in great running condition before u leave... best of luck, pace your self, and don't push you or the car... it is easy to get road hypnosis for that long of a period of time...
Swift 3 B-A-N-G-E-R
Gallon of water and maybe a quart of oil in the trunk wouldn't hurt... Make sure your tires are in good condition... Tire pressure gauge... make sure you have everything needed for changing a tire... Small tool set... cash... Batterey cables... Flash light... pocket knife... condom... jacket... microfiber towel or rag (keep the TL looking nice)... Matches and a lighter... Roll of TP... cell phone... snacks and Gatorade (big mouth bottle)... Never know when you might have an emergency...
Your car should hold up... the list above is for safety only...
Truck driver Gas stations have showers and usually have some restaraunts in them and are well lighted... FYI...
Other then that, you have everything covered in your list.... I know this because every year i make a trip from Salinas, CA to Yuma, AZ which is about 500 miles if i remember correctly... Will be doing it this November again and i'm going on 235,000 miles on my 2.5... So you should definatly be good...
Good Luck on your trip... and congratz on the new job...
When was the last time ypu have changed antifreeze? I am not sure if it is done at the time of you replaced timing belt.
I have 97 2.5 with 230k now. I drove it from Atlanta to NY city and back, 1800+ miles, no problem. I only changed oil and all 4 tires before hand.
You are ok.
You are ok.
1998 2.5TL
Thanks for the feedback guys!
Kamlung - my first project is for a client in NJ, so I'll be working in NJ for a few weeks initially. I'll keep an eye out for you.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Spooky - thanks for the best wishes and the road tips! I'd almost forgotten the condom!![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Meazz - The antifreeze was changed with the timing belt job (700 miles back). I decided to go with antifreeze from the stealership... I know it was overkill... the fockers charged me 15 bucks a gallon! I could've just gone with the regular stuff from any auto store, but I wanted to see blue coolant in my reservoir![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
The tires are in very good shape... I'd replaced them 18K miles back and I've been rotating and balancing them every 6-8K miles.
1998 2.5TL
Originally Posted by KaMLuNg
just shoot me a PM if u r in town.. i can come meet u up for a beer or something... ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Make sure ALL the lights work
pump the tires up 2 psi for the trip- check the spares pressure too
Check the lug nuts 80 ft lbs torque
A can of Seafoam in the tank and in the intake will clean the injectors nicely for you
see gen2 thread Seafoamed the Ol TL for details
Find some 80s rock and set the cruise control~ I cant drive 55!!!!
A 30 minute nap will make you safe again to drive.- Use the rest areas!
Driving long periods is like an airline flight- bad health issues can result from lack of movement- squirm and shift in the seat and get out and walk around and stretch- lay flat on a table- helps prevent back strain- use the lumbar heat!
Enjoy the scenery
Enjoy the scenery
大日本帝国
~Cheers~
1998 2.5TL
Hey Spooky, my trip has been delayed due to some issues with the paperwork. I'll probably be making the drive sometime in the third week of September and I'll probably be in NJ sometime in November. I'll keep you posted. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Thanks for the tips 01tl4tl. I just used a can of BG44K in my fuel tank about 1000 miles back. I've heard the car smokes a lot while seafoaming it... and since I rent an apartment, I don't really have a place to seafoam it without the risk of having people complain
1998 2.5TL
Update - reached Boston
Guys, finally made the trip. No hassles and no issues at all. I think it took me about 22 hours of driving. And that was because of the traffis in NYC! I drove up 95 and I didn't know it passes right though NYC... I should've bypassed it. It took me about 2 hours to cover those 20 odd miles.
Stopped overnight in Virginia... am very happy I decided to drive.
Now I'll need to prepare the car for the Boston winter. I'm thinking about an engine block heater or remote starter.
Also, washing the car in winter is going to be a pain. I hate taking her through a carwash. I used to handwash it when I was in AL... don't think I'll be able to do it in Boston during winter.
'13 Hyundai Sonata
Also, washing the car in winter is going to be a pain. I hate taking her through a carwash. I used to handwash it when I was in AL... don't think I'll be able to do it in Boston during winter.![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
mada51589
05-03-2022 08:54 PM
Legend2TL
11-20-2015 07:31 PM
mugen_kid
11-13-2015 10:38 PM
