Does anyone have a short air intake on thier 2.5?
Originally Posted by Haikoo
So I go into a shop today and they tell me they can't fit any short air/cold air intakes on my 2.5 !! I guess I'll have to make one myself...
Either way... I HAVE A SRI!!!
Weapon-R Short Ram Intake for my 98 2.5 TL... with some other goodies they hooked me up with...
Did you make that or did you buy it??
I got a question...when you open the factory intake housing you notice an air hole on the bottom.....does that lead to open space between the front bumper and the engine bay? If it does would I be able to run a pipe through it for my cold air?
Sorry to ask but please educate me.
What a cold air intake does to your car that a regular stock intake does not do? What the major benefits of having a cold air intake? Way it's called cold air intake ?
thnx
thnx
thnx
thnx
Originally Posted by TLBaller
you should post this pic up when people ask, "will this fit a 3.2?" I know you will get that question in the future..
on skipping school... should have waited for the weekend...
Anyways... Hope the filter is good enough to stop any dirt and such from getting into the engine... just something you might want to look into... Also, make sure water can't get into the spot where the filter is... that'd be a bad bad bad thing...
Looks cool though... Nothing like a hard days work...
i'm sure it would still work (that's what i did on my beretta...but i took stock air box out. but i'm not sure you'll get the 'forced' induction that is being sough after. never hurts to try tho. then you wouldn't have to take off your bumper.
Has anyone really had a chance to test out the gains between a clean OEM filter/box and any aftermarket (WeaponR or custom) setup? The only reason I ask is because the setup my old car had was pretty effective (volvo) and some aftermarket setups actually got worse performance, because of the filter and tubing grabbing lots of heat off the engine, negating the cold air effect. They layout in comparrison though doesn't look too bad for heat transfer though.
After having it for a couple of weeks I noticed two things:
1) Throttle response...punch it and watch the rpm fly much quicker than before
2) Over 5,000 RPM I get a loud noise...almost sounds like a loud blow off valve
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
johnpancakes014
09-27-2015 12:58 PM
