Dashboard airbag delete???
I have a Momo zebrano wood grain steering wheel which eliminates the steering wheel airbag. I would like to convert my pass. side dash airbag into a delete tray.
My question to you all is this: Has anyone done this? Does anyone make a delete tray that would fit the 1st gen dash? Do any other similar trays fit? i.e. - Ek , Eg, or Dc?
Has anyone tried to fit one with luck? (trimming or cutting) or has anyone fabbed one up from fiberglass?
Always been something I have wanted to do. any suggestions would be nice
And no... I do not care to hear anything negative removing airbags. You do your thing and Ill do mine
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
'13 Hyundai Sonata
If you want to do it, then disconnect the - terminal on the battery wait 10 minutes and you will be able to access it. I believe that it is just a matter of lifting the flap up after that to access the airbag.
Yeah I already figured out the correct way to access and remove it... I dont want to have an empty hole in the dash..
This is a reference picture of an airbag delete tray from an Ek...this is what I want to do:
![](http://icbmotorsport.com/pics/JDM/JDM_EK9_Air_Bag_Tray.jpg)
I need to find an Ek, Eg, or Dc airbag to hold up to mine for reference. Im thinking I can make it work somehow
大日本帝国
I had a tray about that depth in the Accord and trust me, nothing stays. You'd have to line it with a non-slip mat. I had a pen my cigarettes go flying on turns, haha.
~Cheers~
P.S. I don't like airbags, either.
~Cheers~
aka romeo da kid
well if yur good with diy's you can try and get a piece of plexi, heat in an oven for 10 min. but yur gonna need a form in the shape u want to lay the plexi over after u remove it from the oven. let it cool and use a dremel to cut off the excess and smooth the edges. i've seen projector housings done this way and i know it would be easier to da a simple tray. like i said your gonna need a form first. thats acutually a good way (if you already have a tray) to make more and $ell them.
DerrickW
11-15-2015 05:52 PM
