Comparable parts list
Old 01-17-2007, 09:53 AM
Htown slab rider
teekay3001's Avatar
I'm trying to get a list going here to make our parts easier to locate, if anyone knows any part of our vehicle that we can get off a honda accords or legend, type1 or type 2 please insert it in this post., please specify the comparable make/model!
Old 01-17-2007, 02:43 PM
Ken1997TL's Avatar
Received 2,329 Likes on 1,309 Posts
For a 3.2 TL:
Engine: 1991-1995 Legend, 1996 - 2004 RL
Transmission: 1996 - 2004 RL
For a 2.5 TL:
Engine: 1992 - 1994 Vigor
Transmission: 1992 - 1994 Vigor
Both TL models:
2004 RL Chrome shiftgate
1994 - 1997 Accord chrome instrument cluster surrounds
Old 01-17-2007, 06:02 PM
大日本帝国
Go90go's Avatar
For 3.2TL:
Front Suspension: 1991-1995 Legend Sedan
Rear Suspension: 1994-1997 Accord Sedan
Brake Rotors: 1997-2001 Prelude non-SH
~Cheers~
Old 01-18-2007, 08:02 AM
dieguinone's Avatar
oooo i like this thread ...because.... here were i live there arent any others TLs ( i think mine is the only one ) but theres plenty of civics and accords so if something happens to my car i can use the others cars parts =D
Old 01-18-2007, 08:03 AM
dieguinone's Avatar
Originally Posted by Go90go
For 3.2TL:
~Cheers~
excuse me , what does "non-SH" stands for?
Old 01-18-2007, 02:31 PM
大日本帝国
Go90go's Avatar
There was a Prelude Type-SH in that generation. The rotors from that particular model won't fit on our cars, but the "regular" Prelude rotors will.
~Cheers~
Old 01-18-2007, 04:15 PM
dieguinone's Avatar
thaaaaaaaaaaaaaaaank you =)
Old 01-18-2007, 09:49 PM
Ken1997TL's Avatar
Prelude SH = Super Handling
It had ATTS (Automatic Torque Transfer System) that would power the outside front wheel more in a sharp corner.
Old 01-18-2007, 09:59 PM
Capricho's Avatar
rear view mirror identical to early '90's Accords
Old 01-21-2007, 11:16 AM
dieguinone's Avatar
For a 3.2 TL:
For a 2.5 TL:
Both TL models:
For 3.2TL:
~Cheers~
hey guys the parts that you have posted they are compatible with any year 3.2 TL?
i mean it doesnt matter if i have a 1996 3.2 TL or a 1998 3.2TL? are they compatible for both models or for any first gen models?
Old 01-21-2007, 11:48 AM
johnnyhonda3.2's Avatar
These will fit anything 1st gen 3.2tl, unless it is specified for 2.5tl
Old 01-22-2007, 12:58 AM
mtbr64's Avatar
for the 2.5 tl
90-97 accord front and rear struts.
this means u can use coilovers for an accord on your tl i suggest getting some with a stiffer spring rate because our cars are heavier
Old 01-23-2007, 01:46 PM
racerock's Avatar
For 3.2TL:
~Cheers~
Following up on something here...
On the front suspension - are you trying to say 4 dr Sedan?
Reason is that I just tried the 4 door shocks, and they do not fit the 3.2 TL because of the diameter of the bottom of the shock.
My local yard has a 92 2 door Legend, and I'm thinking about yanking the forks to see if they would fit. Any info would be appreciated.
Is there an online OEM Parts place that has diagrams and part numbers (like I have for BMW)? That would make it really nice...
...Never mind on the online parts - found it via Kens post in another thread.
Old 02-03-2007, 02:00 PM
Htown slab rider
teekay3001's Avatar
so what particular shocks actually fit the 3.2TL then, if you really dont know then please do some research before posting because it could be very misleading and may have someone spend money buying an item that isnt really compatible with their vehicle
Old 02-04-2007, 07:46 PM
racerock's Avatar
I guess you are asking a general question there because it is quite confusing. Like you suggest, I went and bought a pair of front shocks from a Legend based on someone elses post, and they do not fit a factory setup.
I am in the middle of figuring out a way to get them to fit, however.
So, for now, the only ones I know of that fit are ones from Acura - unfortunately.
Old 02-10-2007, 08:37 PM
Yo Bit** In My Whip
NyRider's Avatar
wHAT ABOUT THE BACK
If the front shocks dont fit dose that also mean that the rear struts also dont fit
Old 02-11-2007, 03:20 PM
mtbr64's Avatar
the accord struts are for the 2.5 only!!!!!!!!!!! they will not fit the 3.2
Old 02-11-2007, 03:41 PM
tcrow31's Avatar
what shocks fit on the rear of a 3.2 other than stock??
Old 02-12-2007, 06:44 PM
Yo Bit** In My Whip
NyRider's Avatar
so basically there are no
Code:
interchangeable
? suspension components for the 3.2tl
Old 02-13-2007, 12:37 PM
tcrow31's Avatar
For those wanting to lower your 3.2 TL check out these links
https://acurazine.com/forums/showthr...hlight=springs
https://acurazine.com/forums/showthread.php?t=123907
Old 03-23-2007, 02:37 PM
racerock's Avatar
Update on the Front Shocks:
-I was able to get the KYB Shocks for the Legend to fit a 3.2TL by using a pair of Shock Forks off a Legend Donar Car
-Direct bolt on.
Old 03-23-2007, 02:50 PM
Htown slab rider
teekay3001's Avatar
WTF is a legend donar car?
Old 03-23-2007, 05:37 PM
大日本帝国
Go90go's Avatar
He meant Donor Car, or some parts car that's a Legend.
~Cheers~
Old 03-24-2007, 09:39 AM
racerock's Avatar
DOH! spelling mistake
Yep, like go90go says, pull the forks out of a donor Legend (Junkyard, or whatever) to "donate" the forks for your car.
Old 03-26-2007, 01:22 PM
Htown slab rider
teekay3001's Avatar
oh ok, i wasnt trynna be funny because there's still a whole lot that i dont know about this car or others, like i just found out today that they got a toyota that looks like the old GS300, that i never knew about, but thanks for clarifying that Go90go
Old 03-26-2007, 06:08 PM
大日本帝国
Go90go's Avatar
NP, m8.
~Cheers~
Old 04-01-2007, 11:18 AM
My 1st Car
96TLPrem's Avatar
Hello everybody,
I have been following this thread for some time to find out about replacement parts. I haven't had the need to post until now.
My 96 3.2TL needs front shocks and according to your information and experiences any 91-95 legend front shock would match. I would like to know if I have to pull them out of an at least 12 years old legend? Can't I just get KYB GR-2 or Monroe SensaTrac from a car parts store?
Old 04-01-2007, 12:07 PM
大日本帝国
Go90go's Avatar
You could if they made them...
~Cheers~
Old 04-01-2007, 12:26 PM
My 1st Car
96TLPrem's Avatar
Check out the link below;
http://www.partsamerica.com/ProductL...Strut%2c+Front
Old 04-01-2007, 12:35 PM
My 1st Car
96TLPrem's Avatar
Advance auto sells KYB and Monroe, autozone sells Gabriel ultra shocks for 95 legend GS. The URL above doesn't work because of cookies. Check out for yourselves.
Old 04-01-2007, 10:12 PM
B A N N E D
Colt45's Avatar
91-95 nsx calipers with 95 legend gs *coupe* front rotors
Old 04-02-2007, 06:25 AM
racerock's Avatar
Originally Posted by 96TLPrem
Hello everybody,
Well, you need to reread this thread a little closer (and look at my postings here and in other threads for the clues you seek).
I did a little more of a write up on another thread on how to get Legend Shocks to fit. It is not a direct bolt on, but very, very close.
Old 04-02-2007, 06:26 AM
racerock's Avatar
Advance (advanceautoparts.com) had them at the best price when I bought mine.
Old 04-29-2008, 12:35 AM
paul.4900's Avatar
hey just got a TL today, 2003 type-S non-navi, but the transmission box or caseing has a crack where all the oil leaked out, im trying to find out what transmissions would fit my car, does the tranny have to come form a type-S to fit mine? will 99 or 00 or 01 or 02 tranny fit my 03-S, thanks hoping to get these answers soon.
Old 04-29-2008, 06:50 AM
racerock's Avatar
Talk about a non searching, random posting in the wrong forum not knowing what to ask first timer...
Old 08-19-2008, 05:45 AM
8th Gear
rdtx2005's Avatar
For 3.2TL:
~Cheers~
i'll add mine findings:
Front Brake Rotors: 1991-1995 Legend Sedan
Air Conditioner Compressor: 1991-1995 Legend Sedan (Engine in the engine must look similar) and you need a slight modification
Alternator: 1995-1995 Legend Sedan (again, Engine must be facing the same way)
Old 08-20-2008, 02:44 PM
大日本帝国
Go90go's Avatar
We have the same engine, haha. Only difference is one's OBDI and the other OBDII.
~Cheers~
Old 08-20-2008, 02:56 PM
大日本帝国
Go90go's Avatar
Oh, I shoved Legend rear brake pads into the 3.2 calipers and they worked with a little massaging into the holder. They're slightly too long, but will get in.
~Cheers~
Old 08-20-2008, 07:15 PM
karma123's Avatar
Will the 92-95 Vigor be my only option for engines for my 97 2.5TL?
Old 08-21-2008, 09:05 AM
8th Gear
rdtx2005's Avatar
Vigor 5 spoke Rear Rotors may be the same
Quick Reply: Comparable parts list
