Changing compressor
Old Aug 20, 2006 | 06:07 PM
klp45's Avatar
Changing compressor
I've had some issues with my ac for the last few weeks. Sometimes it blows cold air and other times it blows hot air. Its making a really weird noise in the engine bay also. I bought some coolant and recharged the thing and it still does the same sporadic stuff. I took it to the dealer on 8/18 (Proctor Acura in Tallahassee, FL) and they quoted me $1385.00 to start. They said that the bearings in my compressor were bad and that I needed a newcompressor and coil. Like I say, it works sometimes and when it does it acts exactly like it should - cold as F@#K on 67. I was thinking maybe a bad clucth or loose belt.
Is it possible to change the bearings and not have to by a compressor?
Could I change out the whole compressor and have them flush and fill it or rather fill it?
Is $1385 for starters an insane amout?
Anyone have directions on how to change it?
Old Aug 20, 2006 | 07:05 PM
TexasHonda's Avatar
The clutch bearing may be dry and making noise. If noise is persistent whether clutch is engaged or not, the clutch bearing is likely. Clutch bearing can be replaced w/o discharging if you can access the face of the compressor. Defintely do-able on a 2.5TL. Don't know about a 3.2TL.
Remove clutch plate center bolt, remove clutch plate, remove snap-ring retaining clutch pulley, and remove clutch pulley. Bearing is contained in the clutch pulley. Best bet is to buy a new clutch pulley w/ bearing installed. If you can't find a pulley by itself, buy a used clutch assy and use that pulley. Be sure to adjust the clutch gap to 20 +/- 6 mils by adding/removing shims behind the clutch plate.
A Honda shop manual for your car would be a big help if you're DIY.
good luck
Old Aug 22, 2006 | 06:04 PM
klp45's Avatar
Greatly appreciated. Now I gotta find that shop manual.
oyayjoe
Jan 1, 2019 10:17 PM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
jdm_94-07TypeS
Oct 7, 2015 11:14 PM
oyayjoe
Sep 12, 2015 04:40 PM
Aleax
Sep 11, 2015 11:31 AM
