car sqeeks/squeels
car sqeeks/squeels
Is this something common? My car sqeeks as i step on the gas. It makes my car sound all old and ghetto. im thinking its the cv joint b/c a mechanic told me that i need a new cv boot awhile back but i held out for awhile and now its squeeking (front driver side). Last i looked under there, oil was spitting out beneath the car but not from the oil pan...just from the shocks area. any ideas? How much will this cost me to fix?
Well if you could do it yourself it would be under $200 but the labor will push it up maybe closer to $500 for the joint replacement. Of course you never said if the boot was torn or just leaking. If there just grease leaking from the joint then the clamp probably needs replaced. The clamp was missing on mine and it was a $10 fix and no more grease coming out. It also might not even be your CV joint at all making the noise.
<~~~ changed his when got my rims...
<~~~ crashed about a month later with said rims...
I remember posting this pic before...
Originally Posted by TLBaller
spo: did you get to the point where your car sqeeks?
I saw them do it and what they did is took my stock rims off... took the joint apart... re-packed the bearing with new grease... and put on the new boot and my new rims right behind that... didn't last long... about 1hour to 1hr.30min... Local privatly owned rim shop did it... they did suspension work too so i guess they knew what they were doing...
so your saying yours did squeel but you didn't wait long until you had it checked out? Mine just started to make noise last week so... Im going to get it checked out ASAP! Thanks mucho spook!!!
i paid 88 bucks for each of my cv joint. I replaced both. be sure to make sure that you have a ripped cv boot, like the one in the pic, before replacing. some places will show you the one thats ripped and tell you that both sides need replacement. so make sure to ask them to see both of your boots to make sure its ripped. they'll charge you if you're not careful.
