Bumper lights....HELP
I wanna make my bumper lights constant instead of only blinking when my blinker is on. I wanna find out the right way to do this, other ways i tried i always blew my fuse. So i need your guys help........thanks in advance
Ex-Mod
The best way I can think of doing this is replacing our factory bulb plug. The factory bulb is a 7440 which is single filament. Get a 7443 plug with a 7443 bulb which is double filament. Now you will have 3 wires coming out of the plug instead of 2. Wire 2 the same way as the 7440 was and hook up the 3rd wire to the parking light wires. I think our brake light plug is a 7443 so go to the dealer and tell them you need 2 of them. I've been thinking of doing this for the longest time but never got around to it.
Ex-Mod
You know what. Before you buy anything check your brake light plugs and make sure there are 3 wires coming out of each plug. If theres only 2, then I dont know how you can do it.
Ex-Mod
OK.
#1 - mugsy76, he will have a blinker. The whole purpose of doing what I said is to convert the bulb from a single filament to a double filament. One filament will stay on all the time and the
other one which is A LOT brighter will come on with the blinker. It is the same as a brake light. It stays lit all the time, then gets bright when you press the brake. Both of those functions are
from 1 bulb. 2nd Gen TLs have those type of bulbs for the front corner blinkers also. They look a lot nicer.
#2 - unx979, he means the front bumper blinkers.
Ex-Mod
Originally posted by unx979
hey 96TL, do you have AIM or something? we gotta do some chattin
I ran across a message on this board a while ago about just this thing.
Someone re-wired their light so it was constantly on (same bulbs), but when they signal, the light blinks (this is what I want to do).
Their only problem was that the light blinked fast, as if the bulb was burned out. They mentioned something about resistors, etc that would solve this problem.
I haven't looked into this further, because my car has an extended warranty, and I don't want to fiddle too much!
HTH
Craig
HTH
Craig
Ex-Mod
OK. Tonight I looked at my friend's 2001 Maxima front blinker plugs. They are 1157's which are also dual filament like the 7443's I mentioned. They have 3 wires so the 7443's probably do also. I would do this mod but I think I'm replacing my front blinkers with LED bulbs. Good luck for whoever tries it though. If you guys dont know where to get the plugs, I know someone from www.autolites.net that can get them. If anyone needs help, ask me.
quanaman
01-09-2023 07:33 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
