bolt broke when changing flat
I was changing a flat when one nut wouldn't come lose. I ened up breaking the bolt. Now my wheel is held by 4 bolts. Can a new bolt be attached or am I looking at a major problem?
Thanks for the help
Thanks for the help
Yes, wheel bolts can be removed and replaced-you will have to knock the old bolt out with a hammer, and have a machine shop press a new one in place... good to do them all while your at it to avoid another problem... The bolts should only be 1 or 2 bucks a piece and labor to press one in should only be a buck or two per bolt... Much cheaper than uneccesarilly replacing the whole hub
ahhh this is where I come in. *cracking knuckles* learn from a thief here. LOL
get you a small blow torch, blow it onto the broken bolt. Wait until it gets hot and reddish. Then get you a flat head screw driver and a hammer (a plyer may help too). try to get out off while its soft. No lug lock or gorilla lock stand a chance. :x
Thanks for the help
Thanks for the help
Originally Posted by JPTL-S
After rebalancing the wheels the tire tech went ahead and bolted the wheels back on and unded up snapping of a portion of one of the bolts.
