Bleeding Brakes
usually u would go in the reverse order in which the booster fills them. i know on mustangs(79-93) the right rear fills up first then the left rear then the right front then left front. i would say it really doesent matter as long as u start in the rear somewhere. since the rears fill up first. and remember DO NOT RUN UR RESUVOIR DRY, OR U START OVER.
good luck.
good luck.
According to the manual:
Start with front driver's side. Then Pass. Then Right Rear, left rear.
Two man job.
Use Honda Brake Fluid.
Use hose to divert bleeding fluid to small container.
Two man job.
Man, I was changing a caliper and I let the booster go dry...Didn't have the patience to bleed myself, limped over to the dealer, got an '03 RSX for a loaner and paid them $200 to do it for me! I don't mind DIY, but bleeding the whole brake system is just not my cup of tea!!
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
