bigger brake conversion...
#41
tried to get a better angle...
![](http://i8.photobucket.com/albums/a17/buucket/CIMG0083-1.jpg)
![](http://i8.photobucket.com/albums/a17/buucket/CIMG0084-1.jpg)
I would hope its over = its over, or maybe you're speaking gaelic? Exactly when was that said though? You may have said something a couple days prior, but your reactions weren't expressed til afterwards. How could I judge you on something before it occurred? I was quoting the past because in the present you were contradicting what you said.. =T Get it? You try to pick apart my words, but it proves nothing really.
#43
I basically handed him a box of goodies; plain brembo rotors, akebono pads, goodridge Legend-brakelines, some 2nd-rate TL-brakelines [just in case], and used Legend calipers...
#44
大日本帝国
Actually, there's a chance you got smaller rotors. There were two types that fit the Accord V6s from those years: one's 260mm and one's 282mm. Your original rotors are 282mm. Double check your sales slip.
~Cheers~
P.S. and Yes, all Legends that weren't Type II had single piston calipers.
~Cheers~
#47
大日本帝国
The calipers can be made to work, but it's the rotors that we're talking about. The Type 2 were 21mm, IIRC, vs the stock 19mm on the 3.2. AFAIK, 21mm is actually the thickness of your rotors, too.
~Cheers~
~Cheers~
#50
~Cheers~
~Cheers~
No I did not get thinner rotors, nor did I get same-sized rotors... infact, they were thicker than my stock rotors so you may have rethink you info.
#51
大日本帝国
Thanks, I've been informed of the years I needed for my calipers... I was one year premature and thus I have single-piston calipers. >.< d'oh!
~Cheers~
P.S. Oh, and weren't you comparing new rotors to old? Of course the new ones would be thicker!!
#52
#54
Yeah, I didn't get ripped off... I got what I paid for. I just didn't do enough research into which Legend calipers I'd be getting. I had assumed all the calipers were the same for that generation Legend... didn't know that hadn't started making type-II calipers until the following year in '93.
But I bought cheap parts because I didn't want to go all out on my braking system until after the 5-lug conversion. Or else I would've done front and rear, with brembo cross-drilled rotors, and higher performance akebono pads... But now I'm considering going with the NSX calipers instead of Legend when I finish this project.
#55
大日本帝国
~Cheers~
#56
I had original Brembo Sport drilled in the red box, not Brembo blanks that were aftermarket drilled. That detail is EXTREMELY important because Brembo won't warranty blanks that were drilled by someone else, and they're structurally weaker because they weren't designed to have holes in them. Stick with the Legend Type II calipers because they're actually better than the NA1 calipers. I like Hawk pads, and hate Axxis because of dust and durability. Whether it was the Metal Masters or the Ultimates, both were garbage.
~Cheers~
~Cheers~
Akebono are the pads for me because they were one of the pioneers with ceramic pads. I opt for ceramics because of dust reduction and they were the original alternative to that nasty asbestos shit.
I thought I read someone mentioning the NSX calipers had like... 4 pistons... which I would assume is a major step up in power... correct?
#57
大日本帝国
I only buy brakes from the source or reputable dealers... brakes are something I don't muck with by trying to save money. (with exception of my rear brakes this one time, only because we are front wheel drive) That is why I went brembo company even if they're regular plates and not cross-drilled, strictly for reliability...
Yes, having 4-pot calipers would improve stopping power provided you had the rotors with the surface area to use them. Another reason for wider tires: contact patch. It's the same for brakes and for tires.
~Cheers~
#58
I guess I'll try to select the thinnest tires to accomodate the NSX brakes... =T
...but, if NSX is overkill and the Legend type-II can accomodate the same thinner tires as stock, I may lean in that direction
side-question... what's the widest rims I could fit without losing turning radius?
#59
大日本帝国
^ Tire width isn't the determining factor on brake fitment. It's the rim size and offset/disk.
About turning radius, I have a tighter turning radius than desired_speeds, and he's stock, while I'm running 7.5". The reason those 20" rims can't turn is not the width (they're all skinny as hell), but because of the height of the wheel, it hits the inside of the fenderwell.
~Cheers~
~Cheers~
#60
Already understood... when I said width.. I meant how wide the diametre of the tires... Again, I should probably be a bit more specific with my choice of words. I was asking what is the largest rims I can fit without losing turning radius... 19s, 18s, 17s? So, the car-jargon would be height = the diametre?
#61
大日本帝国
Height would be including tires. I used to go mudding and wheeling and on the trucks, the tire/wheel combos were differentiated by total height. 32"+ was a must, haha.
I like 16s on this body for a good overall balance on turning radius and looks. I would go 17" for looks, but I do things for practicality, too. For me, a 16" with a almost standard height sidewall is perfect because of grip, ride noise and comfort, and a much smaller change of bending rims. If I had a set of 17" on, then the tire would have to be thinner and I'd have to deal with more noise, not to mention more rotating mass.
~Cheers~
~Cheers~
#62
#63
大日本帝国
You can fit 17" with no problems, as long as you keep the total diameter close to stock. A little over is ok. Factory wheels are 15", with fatty tires for the aforementioned ride comfort.
If you go too much over stock size, the speedo will read slower than you're actually going, too, since the VSS is based on the differential.
Here's one of the most straightforward calculators from the Miata guys:
http://www.miata.net/garage/tirecalc.html
~Cheers~
~Cheers~
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
