Bad Taillights
Old Mar 2, 2004 | 07:12 PM
penguinflies's Avatar
Bad Taillights
this happen to anyone? YOU change a lightbulb to find that it wasn't the light bulb that wasn't working? My new taillights have that problem right now. the brake light won't engage when i'm braking. The parking/nite lights come on fine as every other light. I've tried three bulbs and none worked. Connections look solid plugged in, no loose/fryed wire visible under the plastic guard. Any ideas?
Old Mar 2, 2004 | 08:42 PM
LDH's Avatar
LDH
I
did you check your fuses? Are the new bulbs the correct kind with double filaments?
Old Mar 2, 2004 | 09:59 PM
WBroylesH's Avatar
Had the same problem once. Called the Acura folks and they said that the rear bulbs have been a pretty common problem with folks and that the CL bulbs actually fit better.
Old Mar 3, 2004 | 11:49 AM
yes, the bulbs are the correct w/double filaments. I'll try buy CL bulbs, could just be a connection in the light socket itself. Thanks for the suggestions
Old Mar 5, 2004 | 06:15 PM
CL bulbs dont work, old taillight reinstalled doesn't work, fuse is ok, any other suggestions? the bulbs I got are 12V/5W.
Old Mar 5, 2004 | 07:35 PM
LDH's Avatar
LDH
I
it sounds like you have a short or it could just be a damaged bulb your overlooking thats causing you trouble. It's easy to overlook a messed up bulb. My accord kept on blowing fuses because i moved one bulb that was damaged. do any of your brake lights work? one damaged bulb will cause all of them to fail.
Old Mar 5, 2004 | 09:16 PM
all lights, execpt the passenger side stop light, works.
Old Mar 5, 2004 | 09:17 PM
WBroylesH's Avatar
Loose wire or something maybe?
Old Mar 5, 2004 | 10:07 PM
LDH's Avatar
LDH
I
sounds like you got a short. check the bulb socket with a multimeter
Old Mar 6, 2004 | 04:38 PM
ok i bypassed the short so that the light works (but I still get a bad brakelighte indicator on my instrument panel). I gotta take it to the dealer (sigh) to get the entire rear harness replaced. I wonder how much that is going to set me back.
Old Mar 22, 2004 | 03:16 PM
ay man i got the same problem, i got my inspire taillights and my passenger light dont work. its driving me nuts, i bought new bulbs but ive been getting the same problems your getting.
Old Mar 22, 2004 | 04:37 PM
My car is in the body shop and the mech said it was probably a bad ground wire and he'll look at it and replace it. You might want to just take it to a mechanic and find out which wire is bad and have it replaced.
Old Mar 25, 2004 | 01:16 PM
BobbysTL's Avatar
I really think it may be a bad ground. I had a very similar problem with my accord years ago, the Parking lights in the rear would work fine but when I stepped on the brakes the lights would go out and then when I take my foot off the brake the parking lights would come on. Then i realized that my ground was bad. My accord had 4 bulbs in the rear. So one section of my right side wasnt working, so I repaired the ground wire, the the other section went immediately after, so I repaired that, then the left side went and I said screw it and replaced all the ground wires. It was pretty funny when I look at it now, but back then in that predicument it was quite annoying.
Plus you have to remember alot of our TLs for some reason take on water in the rear especially our tails, so this causes premature corrosion of our wires on our lights. My Accord had the same problem.
Good Luck!
hrothgar02
Nov 2, 2015 01:29 PM
eastcoastguy
Oct 29, 2015 03:00 PM
Timmy18
Oct 17, 2015 03:58 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
hrothgar02
Sep 28, 2015 11:08 AM
