Auto Transmission Control Unit Location?
I have an AT control unit in the trunk when I bought this car, but I never try it working or not.
Last winter the rpm needle was going crazy, and the car kicked when shift from 1st gear to the 2nd... then it was fine after I put in a new air intake. Today, it happened again.
So I think I would try to put the AT control unit on let see what happen, but I dont know where its at. Anyone here have any suggestion or tip? Thanks
大日本帝国
It makes perfect sense... However the tranny computer is not your problem. Check your fast idle valve for sludge, and liberally spray carb cleaner on all the surfaces inside the valve. That should help the erratic idle.
~Cheers~
~Cheers~
If your check engine light and D4 are flashing, the problem is likely a defective VSS (vehicle speed sensor). I had same symptoms as you describe when my 2.5TL VSS failed.
I agree the TCU is probably OK.
good luck
good luck
Too bad for me! The D4 bulb burnt out
So btw do u know what is it bulb #?
mada51589
05-03-2022 08:54 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
krenaue
09-15-2015 07:54 PM
