Attn: Unx979
Attn: Unx979
Hey whats up bro. I need another helm manual favor from you please. I need to know what the 3 wires coming out of the flasher unit do. I really really appreciate it. I may have found the solution for fixing the LED hyper flashing problem. Thanks!
ok the turn signal switch. one should be gree/blue, green/red, and green/yellow. hopefully those are the ones you need.
green/blue: goes from the left turn signal light to the hazard warning switch
green/red: goes from the turn signal and splits off to the hazard warning switch and the turn signal/hazard relay (under dash fuse/relay box socket)
green/yellow: goes from the right turn signal to the hazard warning switch
hope that helps
hope that helps
