Any Side Marker DIY around?
hahahaha yea he is going to school to become a mechanic and knows about wiring so he would def be able to help out with this. I think that he was talking about installing them in a couples of his posts in other threads.
I was at work all day long, checked it right now. Will def do this.
Yes I was talking about and I am def gonna be a mechanic. Hold on it guys..
I need more than 12 because I am grown up adult...
and ...lol
and ...lol
Taken from HONDASUV: sr-crv post
"i wired mine up to do everything. i figured if i went through that much trouble then i wanted to get my "moneys worth"...lol the sidemarker has 2 wires of course, 12v and ground. i ran the 12v to the 12v of the turn signal. then i wired the ground of the sidemarker to the 12v of the park light. yes you read it right. both wires run to both 12v wires. when each wire doesnt have 12v sent to them (whether its turning or running lights) they rest at ground. so when i use my turn signal, it has 12v from turn signal and ground from park light (resting at ground). then when i use my parklights i get 12v from parklights and ground from turn signal wire. but heres the cool trick, when my park lights are on and i use my signal, it alternates on and off the opposite from my turn signals. it has 12v from the parklight and when i turn the signal on it sends 12v to it to. it has 2 12v and no ground so it cuts off. ill have to get a video of it up for yall to see."
Hmm.. thats a cool trick to do still work with your parking lights but works as turn signal too. awesome. Like I said before I'll def do it, but it will take some time. I am busy with some loan and stuff and I still have to order a set. You don't need a relay but you may want to replace fuse for parking lights and turn signals with a bigger one.
You have not seen nothing yet...nice looking V's in there...looking at some side markers on ebay, can't really tell what will and will not work.
I might have to visit a local BM store and check out side markers if they have them. We need the universal one, that comes with mount....
I am partial to clear lens and amber bulbs...will definitely work for you and me, with our Tl color, tmnhs81!!
How do you get access to the fender via the fender liner? And you just wired it in parallel with the turn signal? No relays or anything?
Finally where did you buy your markers?
Thanks.
Thanks.
Sabers share the same side markers as EK civics, prelude (not sure which ones), and Legend, and im sure a few more cars. So it shouldn't be hard sourcing down a set. I got a set of mint Legend ones off of ebay for $20 shipped.
I found a few clear Accord side markers, with clip and tab to hold them in place. I am ready to order a set, they are not bad in price, $15 shipped. I am just waiting on our master mechanic sensei tmnhs81 to kick us off....I will definitely write a nice DIY...after I am told how to do it....
do you have to tap into both wires of the turn signal or just the positive and ground the other one on the body some where?
I think if you want it like its your side marker for most part and you want it to work as a flasher too (flasher+side marker both) you need two filament bulb and a different holder/connector with three wires 2 for power (1 for flasher and 1 for parking light) and 1 for ground. I am kinda confused right now.. Will get back to you guys with proper wiring instructions.
If you are using them just for flashers, you should just run wires and side splice/solder them into flasher connector in bumper.
Its a long post with alot of confusion, sorry.
