After market remote / door panel security light
I have an after market security with remote lock installed few years ago and I was wondering if anyone knows how to connect the security light on the driver side door that came from the factory alarm, so the security light would blink again?
Colors of wire would help, which one I need to tap into from security light to after market alarm.
All you do is pop out the one the shop added. Connect a tail from each wire. Run it through the door. Cut the factory wire of light. Spice in. If one pair doesnt work flip flop and it will work. Theres only two possiblilties.
Thanks, I will give it a try this weekend.
I looked into it yesterday. I now know which two pairs need to be connected. The problem is, it is next to impossible to run the wire thru driver side into the door.
Do you know a better way to get this done?
Know it isn't. Fairly easy once you look at it.
There a little hole on the door below the harness rubber.
Here's what need tape, wire, metal hanger, 4 connectors and Diagonal pliers.
Inside the footwell on the wall above fuse box theres a rubber cover I would call it, lift it up. You going to need a flashlight. This lets you see into the harness cover. Do this pull the rubber cover off the frame on car. Its just held in by pressure. Now you can stick the hanger through the footwell to the outside of the car. Now fish wire through. Now cut a slit on the bottom of the rubber boot. Run the hanger through it, fish wire down. Now the wire should be through the footwell down the boot. Now run the wire through the lil oem hole. Take out the speaker frame so you can grab the wire from the hole. Now run it to the alarm wires. Spice together. Make sure the wire isnt in the window path. Put boot back on, on the frame. put door panel on. Its really easy just takes lil time to do right. I cant even see the wire i ran.
rockyboy
08-04-2024 10:35 AM
handsom-hustla
11-13-2015 05:04 PM
ahsm
09-09-2015 08:35 AM
