Acura TL 96 Engine swap
大日本帝国
How many miles is "too many"?
If you had maintained it properly, it'd last you well over 300,000.
Tranny kick could be from the rear tranny mount. It's a rather weak one since it was designed for comfort.
Where's your sig?
~Cheers~
Where's your sig?
~Cheers~
Received 2,329 Likes
Its just a bad transmission mount. Its a common problem that can be easily fixed.
If you're really worried about your engine, step up to a 3.5 motor.
When you go from park to reverse, park to drive, neutral to drive etc etc you'll feel a big shift in the car (if the mount is bad)
Default
Hmm..."big" is certainly subjective. I definitely feel a shift in my car when going from park to reverse, but it's not a big one (to me).
Anyone know an aprox price for the mount(s) in question along with a rough price in labor?
大日本帝国
If you can stand your car down for a few days, take out the broken mount a poly it. What I mean is to fill in the mount with polyurethane to make it a solid one. You'll get some more lower RPM vibrations, but response and shifting will improve. It's a small trade-off. You can also poly it with a softer compound, which won't vibrate as much.
~Cheers~
~Cheers~
Once again, we seem to have the exact same symptoms. By cold do you mean when the weather is cold, since when it's warm or when the car warms up in cold weather it shifts smooth when driving normally, it's only when I start driving in winter or something that it's kinda rough.
Str8 Home built
hey dude i know what your talking bout ur tranny.. i got 218,889 miles on my car and it runns like a champ...
lol... your tranny is fine ive driven my car many places.. my car does a little kick to but i can bearly feel it. after the car warms up it goes aways right.. welll try changing the tranny fluid and put some of that lucas tranny fluid... i havent used it in my TL yet but my dad has used it in his other cars and it helped take away that kick... when i change my tranny fluid am put some of that in there tho...
handsom-hustla
11-13-2015 05:04 PM
