acura tl 1996 2.5 cranks when i put on neutral but not in park.
when i put 2 park and turn my keyswitch to crank nothing happens. when i put 2 neutral, then it cranks. i dont know what the problem is
大日本帝国
Try slamming it into the Park position. If it works and can start, then maybe the linkage is loose (unlikely) or the switch is bad. Could also be something blocking it to fully going into Park.
~Cheers~
~Cheers~
mines used to do that i had to press a key down in that hole next to the shifter in order to move it but then i notice a couple of fuses was blown and missing under my hood try replacing or checking to see if u have all ur fuses.
mada51589
05-03-2022 08:54 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
