Accumulator oring size?
i see some stuff at the bottom of my accumulator and I am guessing there is a leak at the connection. esco786, did you ever replace the ring? does anyone else have that problem?
I replaced this oring on a 97 Acura CL, a different ABS modulator than the TL but similar.
I pulled the old oring and had to go to several places until I found a good match. Honda doesn't offer the oring as a part, only the entire accumulator. I don't know the size and the oring I used was not a perfect match, but very close. If you have a good micometer, you should be able to measure the old oring accurately enough to understand the oring dimensions.
good luck
good luck
to replace the accumulator according to the shop manual i need to take the relief plug on accumulatorf, releasing the pressurized nitrogen gas. if i do that, the accumulator is useless..
should i just skip that step?
i understand that i need to deppresurize the brake fluid..
ExcelerateRep
10-14-2015 08:20 AM
AcuraKidd
09-25-2015 11:18 PM
