ABS light code 48
Old May 15, 2007 | 04:32 PM
Excell's Avatar
9th Gear
ABS light code 48
I have a 96 Acura TL 3.2 L The ABS light is on and gives code 48 problem is there is no code 48 in the book . There is a 38 I thought I might be counting wrong so I did it again . I still get 48 any help would be appreciated .
Thank you
Excell
Old May 15, 2007 | 06:36 PM
Colt45's Avatar
B A N N E D
Id take the bulb out
Old May 15, 2007 | 08:14 PM
desired_speeds's Avatar
and rip out the ABS for weight reduction
Old May 15, 2007 | 09:24 PM
Excell's Avatar
9th Gear
Both very good ideas ,how ever in this country you can't sell the car if the ABS doesn't work . We are trying to avoid the dealer as they already charged us $40.00 to tell us to replace a wheel speed sensor that didn't fix it . I think that if I could find out what the code means I could fix it .I am hoping that Texas Hondo will see this post an give me the answer .
Old May 17, 2007 | 03:08 AM
arshdeep99's Avatar
PM me your email id. Texas had sent me a pdf with DTC codes when I was trying to diagnose the reason for my ABS light being on. That might help you.
Old May 17, 2007 | 07:40 AM
Excell's Avatar
9th Gear
Thanks for the help . I replaced the left rear wheel speed sensor and the light is out .
mada51589
Jan 9, 2025 04:40 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
Stu2414
Aug 30, 2015 07:30 PM
