98 2.5 TL side-view heated mirrors
The heat on my passenger side-view mirror works, but the driver side dosen't. Is this caused by a bad fuse, switch or wire? Has anyone else had this same problem? What did you do?
It's possible you could have a wiring fault or poor ground on the driver's side, but more likely the heating trace is open. You'll have to remove the door panel to check. That's a good buy on ebay. If you can't live w/o the mirror heater, better grab it.
good luck
good luck
ITSJESTER
17
12-06-2018 02:29 AM
soupi
14
11-15-2015 11:15 AM
