97 3.2TL Transmission problems
Old Sep 19, 2013 | 11:23 AM
97skeetTL's Avatar
3rd Gear
Heres the problems im having sometimes i can be driving pull up to a red light. When light turns green go to drive and engine just revs up and wont go anyway. Put car in park then back in drive pulls off smoothly. Never seen anything like this before. Please help.
Old Sep 19, 2013 | 08:14 PM
jmb106's Avatar
is the D4 light flashing or a check engine light? If so get the codes read. have you changed the fluid and filter?
Old Sep 20, 2013 | 06:42 AM
97skeetTL's Avatar
3rd Gear
No check engine. I changed the filter and new transmission.
Old Sep 20, 2013 | 07:13 PM
jmb106's Avatar
new fluid or tranny?
Old Sep 21, 2013 | 08:34 AM
jmb106's Avatar
you could check the A/B shift solenoids they are located on the top of the transmission between the back of the engine and the fire wall. you do not have to remove them to test, unplug them and apply 12v to each wire, if you hear a clicking sound they are good if not need to replace.
Old Sep 21, 2013 | 08:50 AM
jmb106's Avatar
iw as wrong those are the lockup solenoids, the shift solenoids are inside the tranny.
pstomps
Feb 20, 2017 03:29 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
max4swag
Sep 14, 2015 07:55 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
