96 TL shift sol. location
as stated above, im needing to know the location of my shift sol B on my 1996 TL, and am also wondering if the screen cleaning will work on the 1G like it does on the 2G.
vipstar (08-01-2012)
ok it seems i was way off here. seems that shift sol a and b are inside the transmission on the secondary valve body. the one i referenced on the bell housing is the lock up solenoid a/b.
im have hard shifts but not slippage or anything just odd, and code p0758.
is that going to be the lock up sol or the shift sol???
and if it is the shift sol inside the trans is that something i can pull and fix myself (without fully disassembling or do i need to just replace or rebuild the trans?
i also have a bad wheel sensor and was curious if this could play into it at all.
here is the info on the part that actually causes the poor shifting. and its kind of a pain (only cause of pidly stuff to pull) but it can be done with the trans in the car. could be fixed really easily over the weekend i think. but have a low range torque wrench on hand.
Acura Part: SOLENOID ASSY., SHIFT (SHINDENGEN)
Part NO.: 28200-PY4-003
LilBootNda3.2 (07-15-2023)
SidhuSaaB
05-30-2020 12:40 AM
Hines57
09-24-2015 01:58 PM
