96 2.5 tl vacuum controlled engine mounts
Old Jun 20, 2011 | 10:55 AM
mbgriggs's Avatar
Can anybody explain the sequence of operation and the purpose of the engine mount control solenoid? It appears that I have a busted mount but when I disconnect the engine mount vacuum hose from the solenoid and put a vacuum pump on the line I have no leak and the problem disappears. When I metered the vacuum on the solenoid, I get vacuum on idle but no vacuum on acceleration.
Old Jun 20, 2011 | 11:17 AM
Ron A's Avatar
Administrator
I moved your thread to the 1G TL Forum, which is more applicable to your question.
Old Jun 20, 2011 | 12:08 PM
Go90go's Avatar
大日本帝国
It stiffens or softens the mid-mounts based on acceleration. If you're just cruising around, it'll keep the mounts soft for comfort, but stiffen it for performance if you get on it a bit.
~Cheers~
Old Jun 21, 2011 | 07:25 PM
TexasHonda's Avatar
It softens at idle and stiffens at speed.
I disabled my 2.5TL mounts to see any idle effect and could detect none. It was same idle (smooth) both ways.
I thought I had damaged mounts but have sinced changed my mind. While I was investigating I decided I would buy Acura Vigor mounts. They are essentially the same but w/o the vacuum stiffness modulation feature,...and about 1/2 cost of 2.5 TL mounts.
good luck
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
Mr.Tea
Sep 14, 2015 09:58 PM
