2.5 Differential Fluid Change Interval
In the shop manual it says every 15000 miles some other people say every 60000
Can we come to a consensus on the right change interval
![what](https://acurazine.com/forums/images/smilies/what.gif)
sorry, what benefit does this differential fluid offer? i always thought differential fluid was...i guess another name for transmission fluid. so according to what ive read so far, its 2 diff fluids? my car doesn't shift gear hard at all, prob b/c i had the transmission flush at my last major tune up (60k) and im now at like 108k.
TL Enthusiast
Originally Posted by KaMLuNg
i would change it the same time you change your tranny fluid since it is essentially for the same component... 'tranny' related...
I agree. a transmission and a differential do basically the same thing, so treat them the same, only with different fluids
Same as oil, unscrew the plug in the base of the differential, drain, reinstall plug, and refill from the horizontal fill plug on side of differential. You will probably need to thread a fill tube down through the engine bay and into the fill opening, while pouring from engine compartment.
good luck
good luck
Texas Honda is right
Dont forget to wipe all the metal filings off of the drain plug tip.
Mine was like 3 inches long and wide full of the shavings. Looked like a turd
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
