1996 Acura 2.5 TL / Timing Belt Change
4th Gear
Was wondering if there was anyone out there who has done a timing belt change on the above model? If so, is there anything I should know before going on with it. I'm also doing a new a/c, alt and P/S belts and a new water pump. If there is anything you could share that would be of help it would be greatly appreciated........
Need a special Acura tool to hold the crank pulley when removing the nut,sometimes the pulley breaks before the nut comes loose.Other than that not to hard.Just loosen the valve cover & sneak the upper cover off.No need to fully remove valve cover.
