water leaking in through engine compartment 97 RL
I have a 97 rl. Recently I have noticed that when it rains or I wash my car the passenger floorboard is soaking wet. I first thought that the heater core was leaking, but discovered that it only happened when it rained and never smelled like coolant. I then tested the sunroof drains to make sure that they were not plugged. They were not. I then took a hose and ran it only on the windshield on the passenger side. It took about 20 seconds and then there was water running under the glovebox like crazy. I cannot figure out how it is getting in there. Any ideas? Thanks,
Acura Service Bulletin B98-028 (Dated 01OCT2001) may answer your question. It dealt with problems associated with water leaking into the car from the front pillars. It applied to all 1996-2001 3.5RL's and a few VIN's from the 2002 model year.
water leaking to passenger seat
on my 96 rl i had that same problem n all it was i had 2 do remove the wipers 2 remove a plastic cover. that covers the drainage next 2 the fender once u remove the cover you will c a black sponge lining that has gone bad n all i did was reinforce it with gray tape or cover it to form more of a wall. n it work i was told this by a window replacement house. hope i xplain it write. i did this year ago
09-15-2015 06:44 PM
