Three problems with my 2000 RL. Help appreciated.
I have a 2000 Acura 3.5RL that has developed a few minor problems.
1.)The front cup holders no longer spring out when pushed, they must be pulled out. Also, they take a lot of pressure to close them.
2.)When the driver's door is opened, the interior lights sometimes flicker or do not come on at all. They work fine when other doors are opened.
3.)The foglights have stopped working. I press the dashboard button and the little light comes on but the foglights do not. I've noticed a bit of condensation behind the lens on the driver's side. Is that enough to short them out?
If you can help or give me any advice on these problems I would greatly appreciate it. Thanks in advance.
well for the fog lights to turn on ur low beams need to be on first
ur cup holder sounds broken, i kinda have the same problem but i just hit it really hard and really fast and it pops out.
and for the other light problem, try using the little select wheel under the cruise control, just move it around
NBP_BALLER
Sep 23, 2015 08:18 PM
Mike Bertram
Sep 10, 2015 09:27 AM
