Steering wheel problems!
Old Dec 16, 2009 | 08:52 PM
timberland73's Avatar
99 TLS6 08 TL
My mom has a 2000 RL and her steering wheel no longer moves up and down. It still moves in and out, but not up and down anymore. Anyone else have this issue? When she starts the car, it doesn't move down like it's supposed to and the buttons don't work either. Any suggestions?
Old Dec 16, 2009 | 09:05 PM
Ken1997TL's Avatar
Blown fuse?
Old Dec 17, 2009 | 08:14 AM
99 TLS6 08 TL
Would there be a seperate fuse for up and down and in and out? I think I'm going to her house tonight, I'll check it.
Old Dec 17, 2009 | 09:40 AM
OLD_HATCH's Avatar
your mother probably has a broken gear in the steering columnn that controls the up and down movement.
its actually pretty common.
I made a how to of what to look for and fix on a different site. Just google how to fix your tilt steering on RL, or something to that effect.
I would post a link, but I believe that's frowened upon here.
Old Dec 17, 2009 | 04:10 PM
99 TLS6 08 TL
Thanks a lot, I'll check for it!
Old Dec 17, 2009 | 09:26 PM
OLD_HATCH's Avatar
Well. I recently received the dreaded broken tilt sterring colum after trying to adjust my wheel when I received it form the shop. Needless to say it was NOT an easy fix. I had a broken plastic gear. Of course this might not be the problem with everyones so make sure to test these things first.
1. reset the steering column module.
This can be acomplished by either disconnecting the negative battery cable, (making sure you have radio codes etc) or disconnecting the 3 plugs from the module itself which is located on the left side of the steering column. If the steering colum module senses something out of place it will stop working that particualr adjustment. Could be either tilt, retract, or both.
2. test the motor.
this can be done by simply applying power/ground to the plug off your car battery after removing the motor from the column. (four phillips head screws)
3. check for broken gear. (most likely cause)
To check for a broken gear you must remove the electric motor first. Only 4 screws like mentioned above. then inspect for broken gear parts or split plastic gear.
Here is a basic digram mof the steering column. The retract/extend motor is on the left side higher up on the column, and the tilt motor is at the right side at the bottom of the column.
Now contrary to what I saw posted on the web, replacing the column is not the only option. If you have a pick n pull or junkyard that will let youremove only the plastic gear you will be in luck. Not only money wise but in time spent.
Now this is only a description for a broken tilt gear but the extend/retract gear should be similar.
1. remove the lower dash cover below the steering colum (pulls off has clips)
2. remove the tilt steering motor. (4 phillips head screws)
3. remove the broken plastic gear. (this parts a little complicated so pics will do the talking)
At the bottom of the column you will find 2 12mm bolts on a shaft. These serve as a stop point for the tilt mechanisn so remember or measure its distance.
You will need 2 12mm opened end wrenches as the purpouse of the larger nut is to serve as a stop point and the second nut is to lock the first in its place.
After those are removed there is a rather large nut that needs to ne removed. I used a pipe wrench cause its bigger than most adjustable wrenches etc. After thats remove you will see what looks like a threaded plug. You can unscrew this by hand as its fairly easy.
After that there is a ball bearing ring, and seat should come out. If they do not come out on their own, either pull them out or let them fall out on their own when you remove the plastic gear piece.
Now in the space thats left open where the motor once was you can see the gear. turn the gear either by hand or scredriver so that it backs out of the shaft out towards the bottom.(you might have to move the column up and down to give you slack) Eventually it wil come out the bottom followed by another ball bearing.
This is what all the pieces look like.
and this is the empty space left behind
This a comparison of my broken/split gear next to a good one.
Its actually made up of 3 pieces pressed together with a plastic gear that is made on the shaft of the machine. Its impossible to fix.
Here is a picture of all the the parts layed out including the extend/retract gear to the left of the tilt gear. Unfortunately the do not interchange as the are different sizes and it has sealed bearings to the tilt motors open.
Now installation is the reverse of disassembly.
First goes one of the bearings
Second goes the plastic gear which you will have to turn by hand untill it reaches the top of the shaft. It will stop by itself at his point.
Third is another ball bearing
Fourth is the ball bearing seat.
Fith is the threaded plug that goes into the bottom of the steering colum.
At this point you need to do several things. You need to make sure the steering column is at the lowest position. It should just fall there unless your pushing it up out of your way. After that make sure the plastic gear is turned up as far as it will go without jamming it hard into the top. Then you need to screw in the threaded plug piece. You need to bolt it in till it touches and stops, and then back out very slightly. You see this piece is what keeps the gear in its place and keeps it from moving up and down. After that bolt on the large nut that will lock the threaded plug into place. Put on the 2 12mm bolts at the previous position. Install the motor, and reset the system.
After that everything should work as before. One very important note is to verify the tension and position of the plastic gear before the electric motor is reinstalled. If you reach in and try to spin the gear it should only slightly move in either direction. (like an 1/8 of an inch or less) If you can spin the plastic gear by like a 1/4 turn etc you need to tighten the threaded plug till the play is gone.
Now there are two ways to adjust the tilt into a permenant position with either a broken gear and or bad motor.
The first is simply remove the motor and spin the gear inside the column until you reach the desired position. You might have to help along by pulling/pushing the wheel up and down. reinstal the motor and it will stay in that position.
Now if for some reason the gear is just broken to pieces you can simply remove it like explained above and then tighten a tension bolt on the side of the steering column.
There it is. You basicly loosen the large locking bolt and then use a 10mm allen wren to tighten the center threaded plug as tight as you can. This will keep the wheel in the position you want. tighten the locknut and you will be good to go.
I hope this is a good explenation and if there are any questions feel free to ask.
Old Dec 17, 2009 | 09:27 PM
OLD_HATCH's Avatar
hope that helps
Old Dec 18, 2009 | 08:37 AM
99 TLS6 08 TL
Thanks for the info and write up! A little more than I want to get in to but I work at a car dealership, so one of my techs can tackle this job. Thanks again!
Old Jan 2, 2010 | 10:15 AM
eric.wills@fuse.net's Avatar
Runner
I had the same problem. I was able to reset by disconnecting the battery for a couple minutes. Make sure you have your radio code handy before trying this. You will need it to restart the radio.
Old Sep 24, 2012 | 09:47 PM
jayess058515's Avatar
9th Gear
This post was a life saver.
Old Sep 25, 2012 | 09:27 PM
3.5RLv-tec?'s Avatar
An excellent DIY but I have no time
Old Oct 15, 2012 | 06:58 PM
pdbailey's Avatar
I had this problem and it eventually just resolved. I never unplugged anything or had the radio reset, it just started moving again when I bumped it one day.
Old Dec 2, 2013 | 12:37 AM
VCANTU's Avatar
I have done a repair that seems to be working still to the steering wheel tilt problem.
I used the pictures posted by OLD_HATCH to take out the broken part. Since I could not find one at the junk yards I decided to try my own idea....
The white plastic was cracked into two sections....so what I did is to put them back how they should be but seemed there was a piece missing because the gap between teeth was to wide. But there was no other piece missing, it just took a bunch of little taps on the teeth bring back the white collar tight to the center of the metal spool. Once I had the gap the closest it could be, I then mixed J&B Weld and applied it to the sides of the white plastic and let it dry for a whole day or two and then used my Dremel to reshape any teeth alignment or remove excess glue. See pictures in the link.
Good luck.....mine is still working and can tilt up and down, in and out. I did disable the auto tilting with the switch on the side of the steering wheel.
http://s1284.photobucket.com/user/ve...lt%202000%20RL
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
PortlandRL
Sep 14, 2015 12:01 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
