RL Shocks
Received 2,329 Likes
Shock replacement
If you dont want to go to your local dealer there was a guy on here from one of the online acura oem parts stores, think his name was "partsguy" or something, they sell oem parts from their dealership at less outrageous prices, im not sure if we get discounts for being acurazine members but we might iono. I bought some rims off them awhile back, saved me a bunch of money
Shock or Strut Help
Good evening all, I have a "04 Rl and the rear seems to be setting pretty low does this mean I need shocks? or do i have have struts that need to be replaced. All help would be greatly appreciated.
04 Rl w/Nav.
04 Rl w/Nav.
Your shocks may be blown in the back if it is sagging a lot. It seems like the only option is to do KYB replacements or go OEM. Since you have the 04 you would want to stick with the OEM since they valved it firmer than the previoous years. Your next option is you can run Koni Shocks from the 91-95 Legend and put them in for the rears as it is a straight swap. If you decide to do the fronts you can as well, but you would need to locate the lower forks, brake bracket, and lower spring perch to use the Legend Koni front struts.
Jeep92 (10-07-2015)
Hey guys.. just check Acura RL Struts - Shock - KYB Monroe - 2005 1998 1999 2002 1997 2000 2006 1996 05 98 99 02 97 00 06 96 - PartsGeek.com or any shop the sells KYB... i have those installed on my 98 .. car rides like new.. actually better than stock
IIDXholic
3G RLX (2013+)
23
10-19-2015 09:40 PM
4drviper
09-23-2015 07:42 PM
