Replacing Alternator, Im Stuck, HELP
I am in the process of trying to swap out my Alternator and i have taken everything apart but the Alternator is still being held in by the Alternator bracket. There is 1 bolt that I cannot get out that is holding the bracket. The bolt is in at an odd angle and I tried to use a swivel socket but it still does not give me the room i need. Has anyone else ran into this problem while trying to remove the Alternator or know of a possible solution to this problem? please help. Thanks in advance.
From a manual I found somewhere:
Alternator Replacement
1. Make sure you have the anti-theft code for the radio,
then write down the frequencies for the radio's preset
buttons.
2. Disconnect the battery negative terminal first, then
the positive terminal.
NOTE: The PCM memory must be reset after reconnecting
the battery (see page 11-125).
3. Remove the battery and battery base (see page 4-6).
4. Remove the mounting bolt, lock bolt and adjusting
rod, then remove the alternator belt.
LOCK BOLT
8 x 1.25 mm
22 N-m (2.2 kgf-m,
16 Ibf-ft)
ADJUSTING
ROD
ALTERNATOR
BELT
MOUNTING BOLT
10 x 1.25 mm
44 N-m (4.5 kgf-m,
33 Ibf-ft)
5. Remove the alternator bracket.
ALTERNATOR
BRACKET
10 x 1.25 mm
44 N-m (4.5 kgf-m,
33 Ibf-ft)
8 x 1.25 mm
22 N-m (2.2 kgf-m,
16 Ibf-ft)
6. Disconnect the 4P connector and harness clip bracket,
then remove the terminal nut and the BLK wire from
the B terminal. Take out the alternator.
BLK WIRE
8 x 1.25 mm
12 N-m (1.2 kgf-m,
8.7 Ibf-ft)
4P CONNECTOR
ALTERNATOR
7. Install the reverse order of removal.
8. Adjust the alternator belt (see page 4-33).
9. Enter the anti-theft code for the radio, then enter the
customer's radio station presets.
buttons.
LOCK BOLT
8 x 1.25 mm
22 N-m (2.2 kgf-m,
16 Ibf-ft)
ADJUSTING
ROD
ALTERNATOR
BELT
MOUNTING BOLT
10 x 1.25 mm
44 N-m (4.5 kgf-m,
33 Ibf-ft)
ALTERNATOR
BRACKET
10 x 1.25 mm
44 N-m (4.5 kgf-m,
33 Ibf-ft)
8 x 1.25 mm
22 N-m (2.2 kgf-m,
16 Ibf-ft)
BLK WIRE
8 x 1.25 mm
12 N-m (1.2 kgf-m,
8.7 Ibf-ft)
4P CONNECTOR
ALTERNATOR
I just replaced the alternator in my '00 RL. I was stuck for a bit until I figured out that rotating the alternator in place aligns things so the alternator slides right out. I did NOT remove the bracket. Two front bolts, two electric connections and one harness connection. Biggest problem was dropping harness nut into the netherworld of deep plastic shrouding. I don't recall whether I rotated CW or CCW, but it was about 45 degrees of turn. As I think about it, I believe I rotated CW so the upper boss would clear the bracket.
cak165
1G TSX Problems & Fixes
09-02-2015 09:21 AM
acura, alterantor, alternatir, alternator, changing, generation, nut, procedure, rdx, removal, removing, replace, secoand, sliders, stuck, tl
