Radio Problems
Old 07-07-2010 | 06:34 PM
jeffsearing1's Avatar
Jeff
Radio Problems
My radio in my 2000 rl started sending code E after battery died. After many calls with Acura. we found that the code they supply will not work. They told me to go to Acura dealer and have them look at it. i am worryed that the radio will have to be replaced. Is there alternatives to this. this sounds like it will get very exspensive. PLEASE HELP
Old 07-07-2010 | 08:00 PM
Ken1997TL's Avatar
Do you have navigation?
If you don't, I might have an idea.
Old 07-07-2010 | 11:22 PM
3.5RLv-tec?'s Avatar
dude this happen same as my 2001 MDX. The code they provided only work with the radio but not the GPS. WTF. They told me to bring the car in and they going to charge me $80 lol. For your situation I think you need to take it to them.
Old 07-07-2010 | 11:42 PM
Ken1997TL's Avatar
Navigation unit is a 4 digit code and completely unrelated.
Radio is a 5 digit.
The reason it's $80 or whatever is because they have to look at the actual serial number on the control unit and then enter that into their database. In other words, they take your dash apart. Its a pain in the ass.
Before you do all this, pop the hood and open your fusebox. Check under the lid to see if there is a sticker that has the codes. Thats where mine are
Old 07-08-2010 | 08:23 AM
vas25tl's Avatar
The Box
Radio is a 5 digit.
This
When I was a dealer, I don't know how many times I've taken dashboards apart just to get the serial number
Old 07-08-2010 | 08:13 PM
OLD_HATCH's Avatar
hmmm
have you tried pulling the radio fuse and the ecm/memory/clock fuse?
sometimes when things are running on extremely low voltage things go out of wack until it is reset.
that is of course if simply entering the radio code for your car isnt working and gives you an error.
that is what its doing correct? the radio is not spelling out code when you hit the numbers?
Old 07-09-2010 | 01:59 PM
Radio is a 5 digit.
Ok thank
Old 07-10-2010 | 11:04 PM
Jeff
I don't have Nav. any suggestion would be greatly appreciated
Old 07-11-2010 | 07:02 PM
Ken1997TL's Avatar
Did you check the lid of the fusebox underneath the hood? Its on the driver's side.
Old 07-11-2010 | 09:49 PM
OLD_HATCH's Avatar
the more details the better.
does your radio spell "C O D E" when you push in the numbers?
Old 07-12-2010 | 07:23 PM
Jeff
Yes it spells out C O D E and when attempted 3 times it spell "CODE E" i have pulled fuses under hood and by driver door. I talked to Acura in california and they called ALPINE to confirm code # and it is correct.
Old 07-14-2010 | 04:48 PM
Jeff
Radio Problems
Acura dealer tells me they will pull the radio and send for repairs. this usually cost around $600 - $800. yikes it ain't happening. Does any body have a radio for sale?
Old 07-14-2010 | 05:57 PM
OLD_HATCH's Avatar
car-part.com
Old 07-14-2010 | 07:33 PM
Ken1997TL's Avatar
I'd sell you mine but its for a Navi RL, different shape/fittings/trim
SidhuSaaB
05-30-2020 12:40 AM
Puma Jim
20
10-20-2016 11:59 AM
Kres43
1G RDX (2007-2012)
10-03-2015 07:16 PM
tristann616
1/2G MDX (2001-2013)
09-22-2015 11:40 PM
vanderveen44
ILX
09-16-2015 10:51 AM
Quick Reply: Radio Problems
