Power windows switch
Old Mar 8, 2019 | 02:50 PM
Javier75's Avatar
9th Gear
The power windows switch in my RL are not illuminated when I turn the lights on. I don't remember if it is or not from factory...do you know?
Old Mar 8, 2019 | 03:57 PM
2000RL's Avatar
Veteran: Navy
Yes, the window switches should light-up when the lights are on.
Old Mar 8, 2019 | 05:50 PM
Javier75's Avatar
9th Gear
So, I have a problem, all my doors windows switches are not lighten up. Where do I start to look? Fuse, relay?
Old Mar 9, 2019 | 09:05 AM
OLD_HATCH's Avatar
The bulbs are probably out.
You have to remove the door panels to replace. Might as well see if you can find some LED ones.
Old Mar 9, 2019 | 12:48 PM
Javier75's Avatar
9th Gear
Thank you. I think that I don't need to remove the door panels to replace, just gentle take the trim panel out with a plastic pry bar. What do you think?
Old Mar 9, 2019 | 04:03 PM
OLD_HATCH's Avatar
If you try to take the window switches out by prying them you will break both switch and panel.
The window switches are screwed in from the back.
You "MUST" remove the door panel to change the bulbs on the power window switches.
Old Mar 9, 2019 | 05:57 PM
Javier75's Avatar
9th Gear
Ok. I understood. I'll remove the door panel first. Thank you for the advice!
know610
3G MDX (2014-2020)
Feb 2, 2017 06:16 AM
thx1138
Aug 12, 2011 12:11 PM
96teeluxury
1G TL (1996-1998)
Nov 20, 2006 11:11 PM
Amoeba
Technology
Dec 13, 2005 11:37 PM
