Navigation Problems
Old Dec 6, 2005 | 02:42 PM
cecklund's Avatar
4th Gear
Navigation Problems
I have a 2000 w/Navi, for some reason the last month or so the Nav has been "lost" I never get the little beams coming off the earth symbol in the upper left corner. It is like I am not getting a signal at all. Anyone know what it could be? Can it just go bad? I have the 2005 DVD update and have had no problems until a couple months ago. No changes have been made to the car in that time.
Old Dec 6, 2005 | 04:22 PM
vp911's Avatar
It is possible that the GPS rcvr may have indeed gone bad. You can probably have your dealer diagnose the problem to figure it out.
Old Dec 6, 2005 | 06:30 PM
blaser's Avatar
You can run diagnostics to the GPS system.
I have 2002 RL and the GPS diagnostics is very nice.
Old Dec 6, 2005 | 08:59 PM
cecklund's Avatar
4th Gear
How do I do the diagnostic? Is it something I have to have the dealer do?
Old Dec 7, 2005 | 03:55 PM
blaser's Avatar
You can do it yourself.
place the key on on, doesn't have to be start.
Press menu.
Now press and hold down the following buttons with the correct order, one after each other and keep them pressed, you should have all 3 pressed.
Menu
Map
Cancel
Menu should come up, be carefull do not change things you don't understand.
Old Dec 10, 2005 | 07:52 PM
cecklund's Avatar
4th Gear
I ran the diagnostic and everything seems OK except it cannot find the satellites. I wonder if it is just the antenna unit or if it is the entire nav unit that I have to replace. looks like I may have to bite the bullet and pay Acura the money to tell me.
Old Dec 10, 2005 | 08:14 PM
vp911's Avatar
Won't Acura tell you without actually charging. I thought they had to give you an estimate of the cost before doing any real work. Our lexus rx300 was out of warranty when we had an issue with it. I took it in for an oil change and mentioned it. They ended up telling me what was wrong and just fixing it free. If you are not far out of warranty take it in for an oil change and ask them about it. They may do a customer goodwill repair on it. Especially if you have been going there for all your service in the past and have a good standing relationship with them.
BoricuaTL
Apr 8, 2016 01:08 PM
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
Feb 26, 2016 03:44 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
Gianni Formica
Sep 7, 2015 08:28 PM
travr6
Sep 6, 2015 02:11 PM
