Navigation Hard Drive Failure
I have a 1999 RL and the Navigation hard drive has failed. Two dealers have told me that Acura went to a CD system because of this. Even Acrua in Calif can't confirm they can fix this even with a replacement unit. Is there an off the shelf unit that I can install that will use the same in dash screen?
Received 2,329 Likes
Your best bet is to find another one at a junkyard.
If you don't have any luck at a junkyard (I didn't) look for a PCMCIA Hard Drive or something similar on ebay. Any kind of pcmcia storage will do and you shouldn't need more than 250-300Mb. I'm not sure about CA, but my maps only take about 220Mb. Then just find someone that has a working hard drive and copy everything over to your new drive.
ohhh.....if only it was that easy. I bought a CF card and covertor. I copied the files from hard drive to CF card. Didnt work
I went to the dealer to see if he could program my CF card. 100 programmed then got an error. didnt work!
maybe somebody that has actually done this can send their feedback.
1997 Nav Hard drive failure
I replaced a hard drive with a PCMCIA card and a 512 meg. compact flash card. It's solid state so it works perfectly. The CA region map is smaller than the NW map which takes in from Washington to Nevada (I think). I bought it on Ebay for $125 plus $10 shipping and it came already programmed. You could do it yourself much cheaper, but not sure Acura could or would program it for you. Onlly drawback is they stopped making update for the old hard drive style nav systems in 2002. Hope this helps.
99 tl 96 97 98 99 rl hard drive
Hey anybody having problems with 99 TL or 96, 97, 98, 99 RL hard disk navigation problem? There are seven regions i beleive. Just know your region by turning on your navigation , setup, info and note the region you have. (could be NE, SC, MG, NV/CA, SE etc......) try to look for it on limewire, and download the software and put that software on a 512mb compactflash card and insert that in a PCMCIA compactflash adapter and your hard drive is ready. That is what dealers sell and money rippers sell and they are solid state drives.
any probs?
vickuknow@yahoo.com
any probs?
vickuknow@yahoo.com
Help a noob?
I think I'd like to try using a CompactFlash card in a PCMCIA adapter, and the parts look pretty cheap. My disk is dead, so I can't get the maps off of it. My only hangup is that I can't find the maps anywhere online....can anybody help me out by posting the December 2002 download of the maps? I'd prefer region 5 (5OG), but I'll settle for anything just so I don't have to stare at the yellow error message! Thanks.
You can install a 00-03 TL or 01-03 CL or 01-02 MDX DVD drive in there without ANY problem. You then need to find yourself a NAV DVD disk and you are set.
I've personally done this on my buddys 99 TL when his HD took a dump.
go to http://www.navhelp.com/ I bought one for my acura and it works VERY nicely! It doesn't over heat and has lasted 4 yrs now.
While I am posting here...I had some transmission work done on my RL back in October. When I got in the car, my navigation was working, but the satellite was not showing up in the top left corner of the screen. Therefore, my car was not driving on the virtual map. The HD is fine. I am wondering if anyone has a suggestion on how to fix this problem. Thanks!
Ultimate DIYer
1999 Acura RL Navi conversion to 2000 or so Navi CD?
Hey would anyone know if the configuration for the Hard drive disk Navigation units could be removed and set up for the CD navigation units? I have that ol' 99' hard drive set up and it just isnt fair that the following year the CD came out...let me know anyone
any probs?
vickuknow@yahoo.com
any probs?
vickuknow@yahoo.com
I haven't been able to find the software on Limewire. What do you enter in the search field?
I have the adapter and a 256 mb cf card. Is it too small for the nw region?
Thanks.
Stan in Ore.
Stan
99RL
I have the NM region (Northwest/Mountain) of map ADB085 (the latest Dec 2002 version). However, I am moving to CA and will need the CA/NV region. I called both dealerships near me and neither of them have the data. Does anyone have the CA region data that they can share with me?
Also, I have some web hosting space, so if you have any region and care to contribute to the cause, send it to me and I will post it online for all to enjoy. Email me at blazinboy.20.jones85 at neverbox.com.
wow. whole thread nobody has a clear solution. this sucks! my HD died too. I wonder if it is possible to take a regular "window mounting" GPS and hook it up to the screen in my 99 RL somehow. this way we won't have to worry about all the other crap.
'00 has the same system as the others ('00 to '03) with the black navigation DVD disc. It's the 2nd generation Acura navigation system.
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
ja17
09-07-2015 06:08 PM
