KA9 JDM honda legend fog lights problem
Hello,
My first post an hope i can find out what the problem is, my fog lights use to work an not anymore just got around to fixing them.
I change the relay an added some new bulbs (yellow) still nothing?? i check the switch inside the car to make sure it was on an everything is working?
Thanks for any help
Thanks for any help
Hello,
Thanks for any help
Thanks for any help
Did both fogs stop working at the same time? If so, then I would start from the switch back into the dash.
I would say the likelyhood of both connectors going bad at the same time as slim to none, unless you drove thru some deep water or something like that. Did you double check and make sure the bulbs definitely are good? Have you followed the wires up thru the engine bay to where they meet?
The bulbs are brand new, no i haven't followed the wires to where they meet will do so to see if there is anything weird. I stay in the cayman islands i order my legend from japan.
2004 Carbon Gray 3.5RL
Have you kept it simple...
and checked the fuse?
Also... not sure if it makes a differnece between the two, but are you driving a 96-98 RL with the fogs in the headlights, or a 99-04 RL with the fog lights in the bumper?
I checked all the fuses under my dash an everyone seem to be good, like i said the green light is illuminated when i push the button it goes to show that the fuse is alright.
Is there anywhere else i should be looking for a fuse for this?
The year of my legend is 2000
I believe the only area for a fuse for Fogs would be the small box under the hood. and just because it looks good, doesn't mean it necessarily is... replace it.
I mean a $0.59 fuse isn't going to break the bank and at least you'll have a little more assurance.
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
