Interior light wont come on
Old Jul 13, 2013 | 09:14 PM
frenchy69's Avatar
I was trying to replace all my interior lights with LED lights.
The front ones worked at first.
But as soon as replaced the dome lights in the rear.
Now none of my interior lights work
I've checked all the fuses wasnt it.
its kind dark I didnt check that well.
I have to mess with them again tomorrow.
So what caused it do you think ?
I am so terrible when it comes to cars I hate working on them because I always screw up.
Old Jul 14, 2013 | 01:33 PM
frenchy69's Avatar
My radio isn't working either
I checked all the fuses under the driver side were fine
Where is the radio fuse at?
Thank you
Old Jul 14, 2013 | 03:58 PM
Pro-Pilot's Avatar
Cash Registered Member
Hmm, should most likely be an interior fuse. Are you 100 percent sure they are all OK? I did an interior LED conversion and didn't have any problems. What bulb are you using? (link)
Old Jul 14, 2013 | 04:56 PM
frenchy69's Avatar
Just put
the 12 led dome bulbs
Old Jul 14, 2013 | 09:23 PM
frenchy69's Avatar
All my interior lights including my radio dont work.
Usually my doors the lights light up.
Now they don't .It had to be the fuse but I could locate it.
I took the radio out,I thought it might be a fuse behind ,I didnt find any.
Looks like I am going to take to the Acura tomorrow.I spent over 3 hrs checking all the fuses today.If anyone can help out and tell me where I can find the radio fuse that would be great thanks
This is stupid .
Old Jul 15, 2013 | 12:35 AM
3.5RLv-tec?'s Avatar
It has to be the fuses. Make sure you double check the fuses (interior light, dome lights, etc...) any fuses that are related to interior in the engine and driver kicker panel. Just remove them and switch them around, make sure it matches the rating. Or best yet, go get new fuses sometime the fuses are old it might causes problem. Do that before taking the car to the dealer they will charge ton $$$. Good luck. BTW, is your parking light and license plate light still working? Check small light fuse.
Old Jul 15, 2013 | 01:03 PM
Pro-Pilot's Avatar
Mister French take a look at this....
http://www.justanswer.com/car/2km7q-...quit-time.html
Old Jul 15, 2013 | 10:11 PM
frenchy69's Avatar
Awesome! Thank you very much !
That was fantastic.I will definitely do that tomorrow.I have been working I couldn't check them today.No radio it really sucks
Merci Mon Amis
Old Jul 15, 2013 | 10:19 PM
Pro-Pilot's Avatar
Let us know what happens. Good luck!
Old Jul 17, 2013 | 06:55 PM
frenchy69's Avatar
I fixed it, it was the fuse under the hood 20A,the diagram help me very much.
Thank you Sir,I appreciate it.
Old Feb 26, 2014 | 04:21 AM
Beatindastreets's Avatar
9th Gear
Maybe some one can help me with a sim prob I got a 97 rl I put LEDs thru out the car inside and out I took my pass door panel off to change the speaker witch I didn't do but anyways plugged everything back in put the 4 screws that hold the door panel on..... Now none of my door lights light up even when doors are open and my roof light is staying on unless I shut it off by pushing all the way to the side... If I open any door or trunk nothing happens but it shows on the dash what's open any help would b great
Old Feb 26, 2014 | 04:24 AM
9th Gear
I also checked both fuse boxes with a test light then swapped me all around still nothing no door lights and roof lights stay on
Old May 3, 2016 | 10:18 PM
Davidswifey's Avatar
7th Gear
This is stupid .
The fuse for the radio is located in the fuse box under the hood. It'seems a 20 amp/yellow fuse
Old May 3, 2016 | 10:26 PM
7th Gear
I feel like an idiot... I replied then seen it was from 2013
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
Sep 14, 2015 10:09 PM
PortlandRL
Sep 14, 2015 12:01 PM
oyayjoe
Sep 12, 2015 04:40 PM
