How do I flush the Automatic Transmission?
The transmission on my 1999 RL is starting to shift a little abruptly. I intend to flush the transmission myself in hopes of smoothing things out a bit.
What is the best way to flush out the transmission fluid? Also, any detailed tips such as fluid capacity, correct type of fluid, drain plug location, etc., would be very helpful.
Do the drain and fill a few times. Follow this thread:
http://acura-legend.com/vbulletin/showthread.php?t=4818
You don't want to use Honda fluid each time (It becomes to expensive) Also, buy a new ATF filter.
www.rockauto.com
has an entire package which includes the filter, and o-ring and gasket which all need to be replaced.
Do the tranny flush first then, right before you fill up with HOnda fluid the last time, drop the oil pan and replace the filter.
www.rockauto.com
Follow this thread for the above recommended ATF Filter replacement
http://acura-legend.com/vbulletin/sh...ad.php?t=66734
Pham Alvan
Mar 16, 2016 09:17 AM
joflewbyu2
Oct 8, 2015 11:16 AM
flyromeo3
Sep 24, 2015 11:24 PM
