Help Help Help
Help Help Help
My 2002 Acura Rl 3.5 wouldn't start when I tried to leave the store the other day. I had it towed in to the house and it started up later that evening, so I put fuel injection cleaner in and filled the tank up and drove it around for 30 mins. Upon coming home I noticed that I lost some power going over a hill. The next morning I attempted to start the car, I heard the fuel pump engage but the car still wouldn't start. After that I didn't hear the fuel pump again when I attempted to try to turn it on. Is it the pump or relay switch under the dashboard.
Check the PGM-FI relay under the steering wheel.
projektvertx (02-10-2017)
Thank you for the tip! my cousin came over and self diagnosed it as a dead fuel pump, but I just don't believe that's the problem since so many acura owners have had the same issue
https://acurazine.com/forums/2g-tl-p...-relay-931252/
PGMFI Main Relay Removal - The Acura Legend & Acura RL Forum
yeah its pretty common for these years of cars to have this issue. A simple reflow of the main relay should help it along. Got a soldering iron?
You can, RELAY ASSY., MAIN for 2002 Acura RL SEDAN|39400-SZ5-A01 : Acura Parts | OEM Acura Parts | Factory Acura Parts
39400-SZ5-A01
55 bucks.
Soldering iron is cheaper but whatever you're comfortable with!
39400-SZ5-A01
55 bucks.
kslocum24 (02-06-2017)
It's pretty simple, you remove the relay and check all those solder joints for cold joints or joints that have cracked. It's a much more macro level of soldering than on an iPhone. I'm shocked you made that analogy
Dang replaced the switch but still crank no start. I guess its time to replace the fuel pump. Its located in the trunk under the carpet directly behind the pull down slot in the seat. Easy replacement right?
Are you hearing the fuel pump prime when you turn the key to IGNITION I?.
